Given the Heat Sink shown; what would be the specs and direction of topology for a Power Amplifier of the not TOO exotic direction for a medium experienced DIY amp builder?
Less than +/- 100 Rails and Class AB FULL complementary output I am not opposed to using something other than the TO-3 holes already in the Heat Sink. I also want to design and build a SMPS(S) for it. Last edited by Krisfr; 18th September 2010 at 02:46 PM. |
#2 |
Did it Himself
You would get about 100W single channel on that, there is no room for devices for a two channel amp. You can buy heatsinks like that new for less than 20 dollars so I wouldn't worry too much about salvaging it. The MOSFETs on there are also worth salvaging if you are going to take the heatsink.
Or did you mean the big slabs?
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more Last edited by richie00boy; 18th September 2010 at 03:13 PM. |
#3 | |
#4 |
two channels of 4pair using MJ21193/4 could deliver a lot of power output into either 8r0 from 50+50Vac or into 4r0 from 40+40Vac.
Extra pairs might allow both loads to be fed from an extra 5Vac of transformer potential. Capacitors above 80Vdc start getting expensive, particularly if you have to specify 160Vdc for a 60+60Vac transformer.
regards Andrew T. |
| High power amp project | megajocke | Solid State | 6 | 2nd October 2008 03:16 PM |
| need power supply advice for future power amp project. | boricuaso | Chip Amps | 13 | 6th February 2008 02:24 PM |
| HELP PLEASE! Choice of first power amp project. | brianco | Solid State | 17 | 20th December 2006 05:40 PM |
| new " SOTA" UCD amp | rha61 | Class D | 6 | 3rd July 2006 11:42 AM |
| Sota turntable belt help | Gabrielshorn | Analogue Source | 1 | 7th May 2003 05:05 AM |
| Page generated in 0.08592 seconds (76.27% PHP - 23.73% MySQL) with 11 queries |
