Studio Reference Amplifier
Old 22nd November 2012, 06:56 AM   #911
DAMANHURI is offline DAMANHURI  Indonesia
DAMANHURI's Avatar
Originally Posted by nuwan View Post
sir DAMANHURI
as sir APEX told cloud you post you're new PCB with 9 pair power trans PA
power amp details in 500W PA amplifier with Limiter, plz
thanks
nuwan
Please Chek
This Page About Studio Reference Amplifier
Best regards - Damanhuri
Old 22nd November 2012, 02:10 PM   #912
veljko is offline veljko
Originally Posted by Junie View Post
Is it possible to change the solder pads of Q7 and Q8 and make the same size of Q9 solder pads?
You've been asking Alex the same quastion before... I can only give you the same answer... it is not enough place in that area, unfortunately.
Old 30th November 2012, 05:27 PM   #913
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
SR200 with protect on pcb, not my work.
Old 30th November 2012, 05:34 PM   #914
44250 is online now 44250  Serbia
44250's Avatar
Send a message via AIM to 44250
Thumbs up .
G R E A T ! ! !
Chop your own wood and it will warm you twice
Old 30th November 2012, 07:14 PM   #915
alex mm is offline alex mm  Romania
alex mm's Avatar
......nice but dual layer , could be done only in factory , not so easy for diy
Old 1st December 2012, 04:17 AM   #916
shravanth is offline shravanth  India
if I use +/-70vfor SR200 how watts at 4ohm I can get
Old 1st December 2012, 08:09 AM   #917
apexaudio's Avatar
I'm sure you could done this on single layer
Old 1st December 2012, 08:12 AM   #918
apexaudio's Avatar
Abot 300 watts at 4 ohm.
Old 1st December 2012, 10:45 AM   #919
R.I.P.
I can get over 300W into 4ohms (actually 35.3Vac into 4r0) from a 40+40Vac transformer that gave +-58.5Vdc at the PSU output.
Why only 300W when using a FET output stage and +-70Vdc for the supply?
regards Andrew T.
Old 1st December 2012, 11:23 AM   #920
Vostro is offline Vostro  South Africa
Vostro's Avatar
I thought SR200 used 2SC5200 BJT as output, not mosfets,
as you said many times bad SOA at 70V, so guess not much current available into 4R.
+1, Ive tried to do my own pcbs and I must say, I look at Mr Alex_MM pcbs for hints all the time, I've learned so much just from looking at his diy style boards.
Thanks Alex_MM.
and great contributions from Mr Apexaudio
Studio Reference AmplifierHide this!Advertise here!
Crown Studio Reference I: beefing up the power supply elac310 Power Supplies 4 28th April 2010 12:50 AM
Reference Amp for studio exhausted mule Solid State 0 5th June 2006 05:39 AM
studio amplifier project? rotation Chip Amps 2 2nd February 2006 04:33 AM
Any website reference for diy Audio Research REFERENCE amp and Manley Studio amp bmpa Tubes / Valves 4 19th April 2004 05:11 AM
Any information , website reference for diy Hi-End computer studio sound card? bmpa Digital Source 5 16th April 2004 04:57 PM
