Studio Reference Amplifier
Old 8th October 2012, 01:31 AM   #851
Arif Budiyanto is offline Arif Budiyanto  Indonesia
Originally Posted by apexaudio View Post
What is voltage measurements on R11 and R27?
Ok I will measure this evening...
Many thanks before...
Old 8th October 2012, 10:35 AM   #852
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
Originally Posted by Arif Budiyanto View Post
I have just got back for couple days out of town. Resistor Voltage Measurements conducted last night. Here there are, Supply was 40VAC/55VDC:
R28 = 0,150V , R29 = 0,91V , R30 = 0,42V
Thank you so much
Best Regards...
R29 = 0,91V or 0,091V ?? What is voltage on P1 ( can be 0V - 0,4V)?
Vbe (BD139) = V(R29) + V(P1) = 0,55V.
Old 9th October 2012, 01:35 AM   #853
Dear Mr. Mile S.,
R11=6,96V and R27=0,15V...
What is P1, I am sorry for asking...
I will measure R29 once again to ensure it's voltage.. also check Vbe voltage...
Thank you so much...
Old 9th October 2012, 07:43 PM   #854
apexaudio's Avatar
Dear Mr. Mile S.,
Voltage on R11 must be 15V, replace R9 and R10 with 1k instead 2k2.
Old 10th October 2012, 01:28 AM   #855
Ok, I will buy resistors to replace R9 and R10...
Thank you so much
Best Regards...
Arif
Old 30th October 2012, 11:08 AM   #856
borbon70 is offline borbon70  Philippines
Circuit can work with IRFP240/IRFP9240 (R30-10k, without C10,C11-100pF). Zobel network with 10R, 22nF and 4R7,10uH is on PSU pcb. MJE340/MJE350 must have heatsink (10mA), amp can work with +/-90V DC rail voltage with more outputs (R20,R21,R22,R23-100k instead 47k, R24-12k/1W instead 6k8).
What is ZOBEL NETWORK means sir? Sorry, i,m just a beginner in diy.
Old 30th October 2012, 11:22 AM   #857
R.I.P.
then move above beginner by doing your homework.
regards Andrew T.
Old 1st November 2012, 02:12 AM   #858
Last night I used jumper instead of R10 (to make R9 and R10 = 2K2 both), measured zener diode 15v (D2) = 7,4 volt .
Measurement also conducted on zener diode 15v (D1) = 7,5 volt with R7 and R8 are still 2K2 each...Do D1 and D2 need to be replaced?
I measured the other SR200 channel, both of D1 and D2 are 15 volt..and I can set bias without problem...
I need your advice...
Thank you so much
Best Regards..
Old 1st November 2012, 03:50 PM   #859
apexaudio's Avatar
Thank you so much
Best Regards..
Yes, you must have 15V on zeners.
Old 2nd November 2012, 01:41 AM   #860
Mr. Mile S...
Absolutely right...
Last night I replaced those two zener diodes, install back 2k2 resistor and check the diodes...Finally I got 15Volt on those ones...Thank you so much..
For the first run I set 1V on R10 (instead of fuse)...
Dc offset measured at 24mv...it is a little bit high, isn't it?...But I have not test the sound yet, it was too late of night....
I will try to take pictures and post them in this forum...
Thank you so much Mr. Mile S. for sharing this SR200 design...
Best Regards...
Arif
Studio Reference AmplifierHide this!Advertise here!
Crown Studio Reference I: beefing up the power supply elac310 Power Supplies 4 28th April 2010 12:50 AM
Reference Amp for studio exhausted mule Solid State 0 5th June 2006 05:39 AM
studio amplifier project? rotation Chip Amps 2 2nd February 2006 04:33 AM
Any website reference for diy Audio Research REFERENCE amp and Manley Studio amp bmpa Tubes / Valves 4 19th April 2004 05:11 AM
Any information , website reference for diy Hi-End computer studio sound card? bmpa Digital Source 5 16th April 2004 04:57 PM
