Studio Reference Amplifier
hello apex sir i have made this coil for SR-200, on 10mm daimeter and 12turns with 1.2mm wire.
Have you measured the voltage and from there calculated the current through these 5 resistors?
Post1 shows 2k2 and 6k8
The 2k2 will have ~26Vdc across each.
The 6k8 will have ~120Vdc across it.
The powers dissipated will be ~300mW and 2100mW
No wonder they are running hot !
Current thru 6k8 is 10mA power dissipate will be 680mW
Thanks for your help andrew
I am using R24- 10k 2 watts not 6k8 is there any problem?
Apex is confirming that the cascode transistor is absorbing approximately half of the voltage drop.
Measure your circuit and post the results.
