Studio Reference Amplifier - Page 66 - diyAudio
Old 31st May 2012, 05:42 AM   #651
Send a message via Skype™ to leonatax
Hi Sir APEX can you share SR400 schematic please?
Regards.
Old 31st May 2012, 08:24 AM   #652
apexaudio's Avatar
Originally Posted by comasus View Post
Hi! Mile
Alex used 4 bc560c where as in sr200 schematic only 3 bc560c are present
why an additional transistor was used ??
Go to post #32.
Old 31st May 2012, 08:25 AM   #653
apexaudio's Avatar
Regards.
SR400 is SR200TEF
Old 31st May 2012, 06:18 PM   #654
shreya is offline shreya  India
Mile
Can I connect input ground to power supply ground directly or I must use 10ohms resistor?
Old 31st May 2012, 09:28 PM   #655
apexaudio's Avatar
Originally Posted by shreya View Post
Mile
You can connect directly, 10ohms resistor you can add anytime if there is hum or noise.
Old 8th June 2012, 03:56 PM   #656
JOHN BALI's Avatar
Default 3D preview
Hi all,
I create new layout again, because I can't start make any PCB etched yet.
I hope this is the best I can do, new size is 205 mm x 68 mm
I make it wider so there is enough space between output transistor so the heat can be spread quickly
One more thing is there really good deal if I change the all 2.2uF/100V to the higher value,
I only have 10uF/100V, if bigger is good deal I will change it again
Thank you, I wish you happy
peace & G B U
Old 8th June 2012, 04:35 PM   #657
DAMANHURI's Avatar
Originally Posted by JOHN BALI View Post
Hi all,
Good Job Mr. Jhon.
Best regards - Damanhuri
Old 9th June 2012, 09:56 AM   #658
Nice layout.
But, is it worth squeezing the PCB down to 205 by 45?
That would allow 2 PCBs on a single 205 by 90 board to save costs.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 9th June 2012, 02:41 PM   #659
JOHN BALI's Avatar
That can be done, but I like this board
There are space on three TO-126 for the heatsink of course.
I can't find 3D model for heatsink
For the input caps also enough space for playing with caps
205 because I bought 205 x 205 board size
divide by 3 = 205 x 68 mm.
I will try it but only one thing...
Do you think larger caps on boards says 470uF will bring much improvement?
If we have enough caps on the main PSU
worth?
peace & G B U
Old 9th June 2012, 03:04 PM   #660
470uF for what? Local medium frequency decoupling? Then 470uF is probably sufficient, most amplifier get away with 100uF for the MF decoupling.
Have you got HF decoupling? Is it in the correct place, or places?
regards Andrew T.
Crown Studio Reference I: beefing up the power supply elac310 Power Supplies 4 28th April 2010 12:50 AM
Reference Amp for studio exhausted mule Solid State 0 5th June 2006 05:39 AM
studio amplifier project? rotation Chip Amps 2 2nd February 2006 04:33 AM
Any website reference for diy Audio Research REFERENCE amp and Manley Studio amp bmpa Tubes / Valves 4 19th April 2004 05:11 AM
Any information , website reference for diy Hi-End computer studio sound card? bmpa Digital Source 5 16th April 2004 04:57 PM
Copyright 1999-2017 diyAudio
