Studio Reference Amplifier - Page 54 - diyAudio
Old 2nd April 2012, 10:41 PM   #531
apexaudio's Avatar
Originally Posted by P_0815 View Post
Dear Apex,
i build your PSU for my amp. Therefor i changed the values of a few parts (see picture) for DC output voltage from 34V to 42V. The PSU regulate the voltage really well, but after a few minutes the transistors MSPA42 and MPSA92 will be hot. Where is the mistake?
What is the input voltage? Replace 1k2/1W with 2k2/1W or 3k3/1W.
Old 3rd April 2012, 08:57 AM   #532
apexaudio's Avatar
and there is no mistake with 50 vdc on regulator input you have about 300mW on MPSA42/92
Old 3rd April 2012, 02:00 PM   #533
comasus is offline comasus  India
Originally Posted by apexaudio View Post
Yes and you will get 300W at 4ohms, I prefer sound of SR200.
Hi! Mile
then I am going to use this amplifier for PA speakers is that okay?
i think this will be better than b500 in highs as well as lows what do you say?
Old 3rd April 2012, 03:45 PM   #534
apexaudio's Avatar
Originally Posted by comasus View Post
Hi! Mile
Use SR200 for PA speakers and share your expirience,
Old 3rd April 2012, 06:59 PM   #535
P_0815 is offline P_0815  Germany
The input voltage is 50VDC. I changed the resistor from 1k2/1W to 3k3/1W and both transistors MSPA42/92 keeps cool. First of all i thought, if i change the value to 3k3, the current through the zener diode is too low.
Now, the PSU works fine and i can do the next step to integrate the PSU in the schematic of my amp.
Thanks a lot!
Old 4th April 2012, 08:59 AM   #536
nix is offline nix  Philippines
Originally Posted by alex mm View Post
..... Revised PCB this time , much better I hope ....
Alex.
Hi Mr Apex Sir,
i try this pcb layout #145 but i have problem i got -48vdc at the output using 35 0 35 VAC trafo. I replace bc550 and bc560 to mpsa92/42 and mount in reverse position. sorry i dont have picture of my work. hope you can give me hint/clue on what could be the problem of my work if there is presence of high DC volts on output. thanks in advance.
regards,
nix
Old 4th April 2012, 09:39 AM   #537
44250 is offline 44250  Serbia
44250's Avatar
Send a message via AIM to 44250
Lightbulb just a lucky guess...
Have you placed all the jumpers? There is one in a lower left corner under the 2k2 2W resistors,easy to be forgotten and overlooked.
Old 4th April 2012, 11:09 AM   #538
apexaudio's Avatar
Originally Posted by nix View Post
Hi Mr Apex Sir,
regards,
nix
You must post pictures, there must be some mistake with this high DC on output.
Old 5th April 2012, 08:35 AM   #539
Default Top Side
Bottom will be upload later.
Old 5th April 2012, 10:19 AM   #540
apexaudio's Avatar
Nice work, thank you for share this pcb design,
Crown Studio Reference I: beefing up the power supply elac310 Power Supplies 4 28th April 2010 12:50 AM
Reference Amp for studio exhausted mule Solid State 0 5th June 2006 05:39 AM
studio amplifier project? rotation Chip Amps 2 2nd February 2006 04:33 AM
Any website reference for diy Audio Research REFERENCE amp and Manley Studio amp bmpa Tubes / Valves 4 19th April 2004 05:11 AM
Any information , website reference for diy Hi-End computer studio sound card? bmpa Digital Source 5 16th April 2004 04:57 PM
Copyright 1999-2017 diyAudio
