Studio Reference Amplifier
Old 20th March 2012, 08:44 AM   #491
Arif Budiyanto is offline Arif Budiyanto  Indonesia
Dear Apex,
Thank you so much for your fast response..
Are there any sound changes referring to this change by using 4,7 uf instead of 10uf? Because it means that the new one is less than 50% comparing to the previous value.
Many thanks.
Best regards,
Arif
Old 20th March 2012, 09:23 AM   #492
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
Originally Posted by Arif Budiyanto View Post
Dear Apex,
Many thanks.
Best regards,
Arif
Sound changes is unaudiable
Old 21st March 2012, 04:47 AM   #493
Ok, I will try it!
Many thanks..
Arif
Old 23rd March 2012, 01:53 AM   #494
jprco is offline jprco  Canada
New to this thread and would like to start at square 1 with SR50 but can't get BF420/421. Any suggestions for direct replacement (ZTX457??). See these were dropped in versions of SR100/SR200. Thanks
Old 23rd March 2012, 09:17 AM   #495
apexaudio's Avatar
Use BF471/472 or BF871/872 instead BF420/421,
Old 23rd March 2012, 01:07 PM   #496
Thanks for the quick reply. Unfortunately, the recommended replacements are even harder to source here ie BF471;s/871's! Can you suggest new alternates or a supplier? Maybe I should skip the SR50 and move to SR100...but I would like to start slowly,
Old 23rd March 2012, 02:05 PM   #497
leonatax is offline leonatax  Moldova
Hi Apex can you help me, how can i make protection on rs200 like on ax20p-ax14p
thank you very much
Old 23rd March 2012, 03:17 PM   #498
apexaudio's Avatar
thank you very much
Protection circuit from AX14P can be add on any amp, and on SR200 also.
Old 23rd March 2012, 04:49 PM   #499
apexaudio's Avatar
MPSA42/92 can be use, but pins are E-B-C instead E-C-B (BF420/421)
Old 25th March 2012, 01:41 PM   #500
Dear Mr. Mile,
I am sorry for giving you this question...
What is the best bias setting for SR200 when I measure across r10Ohm (temporary replacing the fuse)?...I read this bias setting before but I forget the value...
Best regards,
Arif
Studio Reference AmplifierHide this!Advertise here!
Crown Studio Reference I: beefing up the power supply elac310 Power Supplies 4 28th April 2010 12:50 AM
Reference Amp for studio exhausted mule Solid State 0 5th June 2006 05:39 AM
studio amplifier project? rotation Chip Amps 2 2nd February 2006 04:33 AM
Any website reference for diy Audio Research REFERENCE amp and Manley Studio amp bmpa Tubes / Valves 4 19th April 2004 05:11 AM
Any information , website reference for diy Hi-End computer studio sound card? bmpa Digital Source 5 16th April 2004 04:57 PM
