Studio Reference Amplifier
Old 11th February 2012, 07:06 AM   #461
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
Originally Posted by Arif Budiyanto View Post
Dear Apex,
At 63 Vdc, mj's were getting warm after few minutes...maybe those were have to be put on heat sink ...
Thank you very much
MJE340/350 must have heatsink.
Old 11th February 2012, 07:41 AM   #462
44250 is offline 44250  Serbia
44250's Avatar
Send a message via AIM to 44250
Originally Posted by apexaudio View Post
I suggest to use TOP3 outputs like SanKen 2SA1294/2SC3263.
For test use 150R/10W instead fuse in 220V AC line.
The pcb should be a little bit bigger,iīd say about 20% . Iīve searched forum pages and pages earlier written but i havenīt found this file,could someone suggest me a page/post where it was posted?
And yes,ALEX MM youīre amasing! I have allready saved two pcb/layouts of SR200 designed by you,and if i find it this would be third!
Thank you for all pcb-layouts given to us!
Chop your own wood and it will warm you twice
Old 11th February 2012, 09:21 AM   #463
naf is offline naf  Indonesia
@44250:
see here for pcb with sanken Studio Reference Amplifier
Old 11th February 2012, 09:49 AM   #464
44250's Avatar
Originally Posted by naf View Post
@44250:
Thank you for trying,but this is the pcb http://i1266.photobucket.com/albums/...p/DSC_0008.jpg that i am looking for.
Old 11th February 2012, 10:58 AM   #465
is this you looking for?
Old 11th February 2012, 11:08 AM   #466
carlmart is offline carlmart  Brazil
I'm sorry, and maybe this has been discussed before, but shouldn't Q11/BD139 be on the same heatsink as the output transistors?
Or as D. Self suggested on his book, bolted to one of the output transistors?
I hadn't paid attention to the pcbs before, so I hadn't realized that.
On a bipolar output amp there should be some tracking of the temperature, and the VBE transistor should do that.
Old 11th February 2012, 12:39 PM   #467
apexaudio's Avatar
This pcb is in post #154
Old 11th February 2012, 12:59 PM   #468
About my comment, it certainly does not refer to pcb on post #154.
VBE transistor is at it should on the same heatsink.
Old 11th February 2012, 02:12 PM   #469
44250's Avatar
Yes yes that is the one! Iīve started with searching from last to first page,that is why i havenīt found it. Thank you so much!
I allready have files for "SR200 V2" and "SR200 V2.3" (both done by alex mm) ,but i havenīt had this one with side mounted outputs. When i begin to do SR200 it will be V2.3 ,and i allready have donor for it,it is some unrepairable amplifier with working 2 x 53VAC 900VA transformer,side mounted heatsinks and good looking fabric metal box with 2 x 14 led power level indicator...more than half parts needed. If i find a picture of it i will post it.
Old 11th February 2012, 02:20 PM   #470
44250's Avatar
That i going to be APEX SR200,one fine day,this year!
Studio Reference AmplifierHide this!Advertise here!
Crown Studio Reference I: beefing up the power supply elac310 Power Supplies 4 28th April 2010 12:50 AM
Reference Amp for studio exhausted mule Solid State 0 5th June 2006 05:39 AM
studio amplifier project? rotation Chip Amps 2 2nd February 2006 04:33 AM
Any website reference for diy Audio Research REFERENCE amp and Manley Studio amp bmpa Tubes / Valves 4 19th April 2004 05:11 AM
Any information , website reference for diy Hi-End computer studio sound card? bmpa Digital Source 5 16th April 2004 04:57 PM
