Studio Reference Amplifier
Old 3rd February 2012, 07:18 PM   #451
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
Originally Posted by sonal kunal View Post
Hi mile, I'm building SR200 for replacement of amp modules of my old yamaha ca2010.
Nice work, and thanks 'alex mm' for this pcb design.
Old 7th February 2012, 07:25 AM   #452
sonal kunal is offline sonal kunal
Thanks alex mm for this pcb and miles for this amp design. it worked for me quiet well because i had limited space for mounting . Other member trying to diy this pcb will problem of "not enough space between op transistors".
my second pcb is completed. I'm waiting for 22000mF cap. hopefully I'll test this week.
Old 7th February 2012, 08:43 AM   #453
apexaudio's Avatar
I suggest to use TOP3 outputs like SanKen 2SA1294/2SC3263.
For test use 150R/10W instead fuse in 220V AC line.
Old 7th February 2012, 11:04 AM   #454
It will take lot of time for me to get SanKen 2SA1294/2SC3263, can I use two pair of MJ15024/MJ15025 as mounting holes are already on heat sink.
Old 7th February 2012, 12:59 PM   #455
apexaudio's Avatar
Yes, MJ15024/MJ15025 can be use.
Old 9th February 2012, 01:59 PM   #456
yassud is offline yassud  Indonesia
Sir Sonal,
If you are using MJ15024/MJ15025, there are 24 strands of wire chases in the box.
If the project is finished I want to hear about it from your review.
Good luck.
Yassud
Old 10th February 2012, 12:32 AM   #457
Arif Budiyanto is offline Arif Budiyanto  Indonesia
Dear Apex,
what is the best suggested rail voltage to supply SR200. And what is the maximum supply for SR200.
Many thanks before.
Best Regards,
Arif B
Old 10th February 2012, 09:35 AM   #458
apexaudio's Avatar
Originally Posted by Arif Budiyanto View Post
Dear Apex,
Many thanks before.
Best Regards,
Arif B
I suggest +/-65V, and +/-75V is maximum rail voltage,
Old 11th February 2012, 12:37 AM   #459
Dear Apex,
At 63 Vdc, mj's were getting warm after few minutes...maybe those were have to be put on heat sink ...
Thank you very much
Old 11th February 2012, 05:16 AM   #460
naf is offline naf  Indonesia
Dear Apex,
Thank you very much
Wow.. nice to hear you've finished it
Studio Reference AmplifierHide this!Advertise here!
Crown Studio Reference I: beefing up the power supply elac310 Power Supplies 4 28th April 2010 12:50 AM
Reference Amp for studio exhausted mule Solid State 0 5th June 2006 05:39 AM
studio amplifier project? rotation Chip Amps 2 2nd February 2006 04:33 AM
Any website reference for diy Audio Research REFERENCE amp and Manley Studio amp bmpa Tubes / Valves 4 19th April 2004 05:11 AM
Any information , website reference for diy Hi-End computer studio sound card? bmpa Digital Source 5 16th April 2004 04:57 PM
