Old 1st February 2012, 09:18 AM   #441
44250 is offline 44250  Serbia
44250's Avatar
Send a message via AIM to 44250
+/-15VDC can be used for a preamplifier,cooling fan or something else,and it is the output from 7815/7915 that is supplied from 2x18VAC. 2x18VAC is the only power supply that comes into the protection circuite. +/-15VDC comes out from the protection circuite and it is result from stabilising voltage after the bridge rectifier.
Old 1st February 2012, 11:19 AM   #442
viki_v2 is offline viki_v2  India
viki_v2's Avatar
can you make some drawing, how to connect protect to Amp, I had read about stereo protect in this forum, don't remember where.
If you try to find a fool, the first person you find is yourself.
Old 1st February 2012, 12:23 PM   #443
44250's Avatar
File Type: txt tekst.txt (508 Bytes, 82 views)
Old 1st February 2012, 12:27 PM   #444
44250's Avatar
That in upper post was for stereo,and this is for mono-one channel:
File Type: jpg APEX H900 Protect Component layout.jpg (664.6 KB, 613 views)
File Type: txt New Text Document.txt (908 Bytes, 56 views)
Old 1st February 2012, 07:35 PM   #445
viki_v2's Avatar
What value volume control potentiometer for sr200
Old 1st February 2012, 09:03 PM   #446
apexaudio's Avatar
5-10k
Old 2nd February 2012, 05:14 AM   #447
viki_v2's Avatar
Originally Posted by apexaudio View Post
5-10k
Mile sir, Kindly check drawing if I am correct.
For Mono protect the relay 24v 16A is it different from relay for Stereo protect having 24v 2x10a.
Old 2nd February 2012, 09:35 AM   #448
viki_v2's Avatar
regarding Sr200 if I use MJL21193 and MJL21194- 2SC5200 Will be replaced BY 21194 and 2SA1943 Will be replaced By MJL21193- Is this correct
Old 3rd February 2012, 10:46 AM   #449
44250's Avatar
Replace pnp with pnp(2sa1943/mjl21193,and npn with npn(2sc5200/mjl21194). Simple as that...
Old 3rd February 2012, 06:56 PM   #450
Hi mile, I'm building SR200 for replacement of amp modules of my old yamaha ca2010.
Crown Studio Reference I: beefing up the power supply elac310 Power Supplies 4 28th April 2010 12:50 AM
Reference Amp for studio exhausted mule Solid State 0 5th June 2006 05:39 AM
studio amplifier project? rotation Chip Amps 2 2nd February 2006 04:33 AM
Any website reference for diy Audio Research REFERENCE amp and Manley Studio amp bmpa Tubes / Valves 4 19th April 2004 05:11 AM
Any information , website reference for diy Hi-End computer studio sound card? bmpa Digital Source 5 16th April 2004 04:57 PM
Copyright ©1999-2013 diyAudio
