Studio Reference Amplifier
Old 11th December 2011, 11:56 AM   #411
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
Originally Posted by leonatax View Post
Sir Apex what do you think about this security system it is for 6 chanel but only for 32+- volts what can I do to use it for 40+-vdc psu
Connect 15V zener in series with relays
Old 11th December 2011, 12:12 PM   #412
leonatax is offline leonatax  Moldova
Old 13th January 2012, 11:10 AM   #413
viki_v2 is offline viki_v2  India
viki_v2's Avatar
Hello Mile,
I will be making SR200 v2.2 With Sanken 2sc2922-2SA1216.
What should ve voltage and Current Requirement for 1 pair and 2 pairs.
As well What will be the output with Single pair and 2 Pairs.
Old 13th January 2012, 11:39 AM   #414
carlmart is offline carlmart  Brazil
Apexaudio,
Some time ago I asked about the possibility of using a dual fet at the input, probably improving offset quite a bit and following paths high quality amps have followed.
Any news on that or hint on how to do it?
Old 15th January 2012, 11:49 AM   #415
JOHN BALI is offline JOHN BALI  Indonesia
JOHN BALI's Avatar
Default Driver TR?
Hi Apex,
I will try to make new PCB design for SR200, it hard I guess
I want to ask it is ok if I separate driver A1837/C4793 from main heatsink?
so the PCB is not so big
I saw your SR400 component side, there is only VBE multiplier (BD139) on main heatsink...
Also can replace A1837/C4793(out of stock here) with A968/C2238(I have some)?
Thank you, I wish you happy
peace & G B U
Old 15th January 2012, 03:03 PM   #416
apexaudio's Avatar
Originally Posted by JOHN BALI View Post
Hi Apex,
You can use A968/C2238 on separate heatsink, output stage of SR400 is TEF, MJE340/350 are predrivers on separate heasinks, and one pair A1493/C5200 is drivers on main heatsink with outputs.
Old 15th January 2012, 03:07 PM   #417
apexaudio's Avatar
Originally Posted by carlmart View Post
Apexaudio,
I work on new amplifiers using dual fet at the input, one will be in thread '100W Ultimate Fidelity Amp' and second will be here.
Old 15th January 2012, 06:27 PM   #418
Thanks, Apexaudio. Looking forward to it.
Also curious on what might be different between those two, as the inputs are very much the same on both.
Old 15th January 2012, 09:48 PM   #419
apexaudio's Avatar
VAS is different like in AX and SR amps.
Old 19th January 2012, 11:57 AM   #420
Sir APEX can I use BC557c(b) BC547c(b) instead of BC560c BC550c, or BC550b-560b
Studio Reference AmplifierHide this!Advertise here!
Crown Studio Reference I: beefing up the power supply elac310 Power Supplies 4 28th April 2010 12:50 AM
Reference Amp for studio exhausted mule Solid State 0 5th June 2006 05:39 AM
studio amplifier project? rotation Chip Amps 2 2nd February 2006 04:33 AM
Any website reference for diy Audio Research REFERENCE amp and Manley Studio amp bmpa Tubes / Valves 4 19th April 2004 05:11 AM
Any information , website reference for diy Hi-End computer studio sound card? bmpa Digital Source 5 16th April 2004 04:57 PM
