Studio Reference Amplifier
Old 10th December 2011, 08:53 AM   #401
irwanks is offline irwanks  Indonesia
my work, sr200 with 1 pair transistors was supplied by 40vac 5 ampere transformer. Sound had nice bass and mid.
Old 10th December 2011, 09:16 AM   #402
amptech is offline amptech  Scotland
Send a message via MSN to amptech
A quick tidy up with some cable ties....
Old 10th December 2011, 09:22 AM   #403
Sir apex, What is the rating watt for 10 ohm resistor between signal ground and ground (1/4 or 1/2 or 1 or 2 watt) ? What is the rating watt for 220 ohm resistor between emitor 2sc4793 and emitor 2sa1837 (1/4 or 1/2 or 1 or 2 watt) ? What is the rating for coil (1uH or 2uH or 10uH, or etc) ? Thank you very much.
Old 10th December 2011, 09:24 AM   #404
Thank you for your ideas
Old 10th December 2011, 12:38 PM   #405
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
U can use 1W resistors and 4uH coil (post #43)
Old 11th December 2011, 01:11 AM   #406
Thank you sir, i will change it. I use one 2k 1 watt resistor before zf15v for 40vac transformer. Is it allright?
Old 11th December 2011, 03:18 AM   #407
apexaudio's Avatar
Use 2k2/2W
Old 11th December 2011, 11:27 AM   #408
leonatax is offline leonatax  Moldova
Sir Apex I have measured volts on 100r resistor and I have 850mv and 2mv on out, is it ok that I use TL071 instead Lf411 and what about TL081
Old 11th December 2011, 11:38 AM   #409
Sir Apex what do you think about this security system it is for 6 chanel but only for 32+- volts what can I do to use it for 40+-vdc psu
Old 11th December 2011, 11:54 AM   #410
apexaudio's Avatar
That's OK
Studio Reference AmplifierHide this!Advertise here!
Crown Studio Reference I: beefing up the power supply elac310 Power Supplies 4 28th April 2010 12:50 AM
Reference Amp for studio exhausted mule Solid State 0 5th June 2006 05:39 AM
studio amplifier project? rotation Chip Amps 2 2nd February 2006 04:33 AM
Any website reference for diy Audio Research REFERENCE amp and Manley Studio amp bmpa Tubes / Valves 4 19th April 2004 05:11 AM
Any information , website reference for diy Hi-End computer studio sound card? bmpa Digital Source 5 16th April 2004 04:57 PM
