Studio Reference Amplifier
Old 6th August 2011, 12:23 PM   #361
drowranger is offline drowranger
Default r 21?
i have made mistake when i post the old schematic and here is the corrected schematic. r21 is connected to power gnd same as apex schematic.input gnd can be connected to power gnd.but in apex schematic he used r36 as an option if hum is present.i have connected pin 3 of ic1 to input gnd same also in apex schematic.
foil pattern had been corrected in last post.
Old 29th August 2011, 01:06 AM   #362
sasek is offline sasek
i finish build this amp. Result is sound very excellent. Low noise. Vocal is clear and i like this amp. i use 2 pair power output. Drive on +-50V. Not use any buffer or pre amp. Use car heatsink. Thanks to apex and alex. More picture for my sr200 here.
Old 29th August 2011, 02:16 AM   #363
overpower is offline overpower
Nice PCB
Edit:
Q11 (BD139, bias regulator), Q13 (2SC4793) and Q12 (2SA1837) should be located at the same heatsink with 2SA1943/2SC5200
Old 29th August 2011, 09:59 PM   #364
right overpower.but that for testing only. i want to make other casing for this amp.
Old 9th September 2011, 09:08 PM   #365
44250 is offline 44250  Serbia
44250's Avatar
Send a message via AIM to 44250
Just great amplifier,judging by the posts of the people that built it! That will be the third one from you APEX. The first one will be the AX12(or a B80),the second NX16 and the third studio reference 200. Now i know what i will build in a next year,two or even more-depends of my money/time sources. It is nice to have such a great people that are willing to share schematics and pcb-s of devices that are tested and risk-to-built-free! Greetings to all of you!
Chop your own wood and it will warm you twice
Old 27th September 2011, 11:05 AM   #366
if my sr200 have some noise.what the mainly my mistake?how to overcome noise?
Old 27th September 2011, 05:19 PM   #367
44250's Avatar
What kind of noise? Deep bass or a sound of a wind through the trees? They are caused by a different things. First one could be from magnetic field of a transformer (if it is too close to an amplifier pcb-s),not enough filtering in a PSU(too small or old capacitors),damaged bridge rectifier...those are all reasons for a deep bass noise. I once had a noise ("wind in a tree"kind) in one other amplifier and it was caused by leaking capacitor 68nF,when I replaced it the noise was gone.
Old 27th September 2011, 06:39 PM   #368
noise like "tettttttttttttttt" not loud but exist.
Old 16th October 2011, 03:44 PM   #369
bedjons is offline bedjons  Indonesia
Ultimate Fidelity use current source and current mirror at differential stage, but I can't see inte Studio Reference. Why? Best regards
Old 3rd November 2011, 09:12 AM   #370
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
Can you post pictures with ground wireing?
Studio Reference AmplifierHide this!Advertise here!
Crown Studio Reference I: beefing up the power supply elac310 Power Supplies 4 28th April 2010 01:50 AM
Reference Amp for studio exhausted mule Solid State 0 5th June 2006 06:39 AM
studio amplifier project? rotation Chip Amps 2 2nd February 2006 05:33 AM
Any website reference for diy Audio Research REFERENCE amp and Manley Studio amp bmpa Tubes / Valves 4 19th April 2004 06:11 AM
Any information , website reference for diy Hi-End computer studio sound card? bmpa Digital Source 5 16th April 2004 05:57 PM
