Studio Reference Amplifier
Old 31st July 2011, 06:50 AM   #351
alex mm is offline alex mm  Romania
alex mm's Avatar
Default .......and so on ....
..... D1 zenner diode must be reversed , R7=1k resistor in wrog position not to pin 4 IC (not this way )..... , output transistors are the same 2SC5200 ? and so on ........
Old 31st July 2011, 08:34 AM   #352
drowranger is offline drowranger
Default thanks for the correction
hope this is fine...
Old 31st July 2011, 09:25 AM   #353
alex mm's Avatar
Default ....not OK
....... forget to link , like in pic .
Old 31st July 2011, 12:11 PM   #354
Default again, again...
thanks,alex...your the man!
and also change the schematic
Old 31st July 2011, 12:18 PM   #355
Default scematic
Old 4th August 2011, 09:42 AM   #356
R.I.P.
IC1 PIN3 ?
If the unconnected PIN3 floats with PIN2 then the 411 output voltage will always be zerovolts +-output offset +-common mode error.
regards Andrew T.
Old 4th August 2011, 09:55 AM   #357
R.I.P.
It is connected to two diodes. Both are connected to PIN2.
As drawn PIN3 floats with PIN2.
regards Andrew T.
Old 4th August 2011, 09:55 AM   #358
Default you are right
Originally Posted by AndrewT View Post
IC1 PIN3 ?
If the unconnected PIN3 floats with PIN2 then the 411 output voltage will always be zerovolts +-output offset.
Old 6th August 2011, 05:06 AM   #359
Default hope its ok now...
thanks andrew for checking.
Old 6th August 2011, 10:51 AM   #360
R.I.P.
You have connected PIN3 to Signal Ground.
Label Signal Ground to differentiate it from Power Ground.
Now a question which ground does R21 connect to?
Show the change on the sch.
regards Andrew T.
Studio Reference AmplifierHide this!Advertise here!
Crown Studio Reference I: beefing up the power supply elac310 Power Supplies 4 28th April 2010 12:50 AM
Reference Amp for studio exhausted mule Solid State 0 5th June 2006 05:39 AM
studio amplifier project? rotation Chip Amps 2 2nd February 2006 04:33 AM
Any website reference for diy Audio Research REFERENCE amp and Manley Studio amp bmpa Tubes / Valves 4 19th April 2004 05:11 AM
Any information , website reference for diy Hi-End computer studio sound card? bmpa Digital Source 5 16th April 2004 04:57 PM
