Old 28th June 2011, 07:07 PM   #331
apexaudio's Avatar
Originally Posted by dentarthur View Post
Anyone else done this too?
I run SR200 on +/- 70V and found that 5 transistors get pretty hot. It all works just fine, however, I made some cooling on the MJE transistors and the 2 BC550's that connect to the + via the 100ohm resistors (see picture).
Isn't it strange that the 2 BC550's on the '-' side do not get as hot as the ones on the + side?
It's strange that the 2 BC550 get hot. MJEs must be hot and BCs must be cold in cascode VAS...
Old 29th June 2011, 04:33 AM   #332
why is resistor r9 and r10 is before the r11.how can you get the ideal 4ma when your voltage is only 15volts?
Old 29th June 2011, 05:18 AM   #333
Luke is offline Luke  New Zealand
Send a message via AIM to Luke
anyone made a pcb for the higher power reg as in post 14?
If you give a man a fish he will eat for a day. But if you teach a man to fish he will buy an ugly hat. And if you talk about fish to a starving man then you are a consultant. Dilbert
Old 29th June 2011, 02:52 PM   #334
anyone?can you please help me on r9 and r10.is it before r11 or after?check me if im wrong r9, r10,d2, and c5 are used to regulate the supply of ic1. im making new foil pattern for this one. thank you for your time.
Old 1st July 2011, 01:23 PM   #335
apexaudio's Avatar
Originally Posted by mathez View Post
thanks to Apex&Alex for this SR200
Nice work, be welcome,
Old 1st July 2011, 01:25 PM   #336
apexaudio's Avatar
I have built one SR200 and have it running on +/- 70V.
I can set bias for it to be at 100mA (10Ohm resistors do not go up in flames).
However, the MJE 340/350 all get very hot. During short up-times I did some measuring and it seems that each of these MJE's has approx 67V between E-C and runs some 10mA. Should these T's get warm with these numbers? Should I heatsink them (I see heatsinks on them in some builds.
Or does this mean that there is an error in my build?
Yes, MJE's need cooling, there is no error,
Old 2nd July 2011, 05:57 AM   #337
Default sr 50
Originally Posted by apexaudio View Post
APEX SR100 Studio Ref Amp
Hope this may help(based on the original schematics of SR50).
ENJOY!!!
File Type: pdf studio reference sr50 pcb foil pattern.pdf (42.7 KB, 397 views)
Old 2nd July 2011, 07:58 AM   #338
correct parts placement guide.(previous is in mirror image).sorry.
Old 2nd July 2011, 02:18 PM   #339
Default sr50 incolored top view
Old 10th July 2011, 11:38 AM   #340
yassud is offline yassud  Indonesia
You can use Coolets pcb design for SR50 and add another pair of outputs,
Sir Apex, can you give examples of schemes SR100 (VAS cascode)? Thank You
Crown Studio Reference I: beefing up the power supply elac310 Power Supplies 4 28th April 2010 12:50 AM
Reference Amp for studio exhausted mule Solid State 0 5th June 2006 05:39 AM
studio amplifier project? rotation Chip Amps 2 2nd February 2006 04:33 AM
Any website reference for diy Audio Research REFERENCE amp and Manley Studio amp bmpa Tubes / Valves 4 19th April 2004 05:11 AM
Any information , website reference for diy Hi-End computer studio sound card? bmpa Digital Source 5 16th April 2004 04:57 PM
Copyright ©1999-2013 diyAudio
