IF Zobel NET has HIGH temp, then there are HI-freq oscillations content superponed to audio content,
you must look OUT signals (before Zobel NET OUT) with oscilloscope,
look at 10KHz square wave OUT response, if are there Overshoot, Ringing, Settling time (or oscillations)
Post some response oscillograms here...
How do you change the bias voltage can be adjusted?That's how it worked. The setting is smooth and fine. I still ask, will 23mV on the emitter resistors be OK?
If everything is correct, by turning the trimmer P1, you can observe the 0R33/5W emitter resistors.How do you change the bias voltage can be adjusted?
Together with a friend, I want to build one of the higher powered APEX amps. We already have a few decent transformers in the 800-1200VA range which needs to be put to work.
At the moment I have come down to 2 different basic designs in 5 (not so) different amplifiers.
Not having the expertise to immediately say which of these would be the better choice, I ask the experts.
The ones I have in mind are the following_
Non symmetrical input: F250 and SR250
Symmetrical input: HV23/HV25 and HV350.2
I have a few questions:
1 - Is one basic design "better" than the other in these amps?
2 - In each group, which amp is going to perform "best"?
3 - Is there a clear overall favourite? (Which one would Mile recommend?)
4 - What supply voltage range is usable for these amp?
Thanks for any input on this!
🙂 morten
🙂 morten
These designs need a boosted VAS voltage to deal with the MOSFET threshold voltage loss and the degenerated VAS loss, which is required by the symmetric IPS (and/or cascoded VAS). An extra +/-6 to 10V would be appropriate. VI protection creates an abrupt output impedance change when in protection that has undesirable results. I would use it to activate an input reduction so that the protection is not fighting with the global feedback. I assume you have built a few amps before. Building a high-power amp is a classic mistake that beginners make that inevitably leads to much sorrow.
Thank you for your thoughts. I have built a few amp, but I don't design amps. So I try to gor for proven and finished designs, or at least some that I think are.
That's why I thought APEX would be a good choice. They have benn build using the published schematics for many years, as far as I understand.
To modify them would be above my understanding.
Two other designs are on my list, along with the APEXes. The Montarbo 1002 and Tecton MK2.
Do you think they would be a better choice?
- Studio Reference Amplifier
