mr mile
i built clip indicator circuit today
it works very well
i want built pp8 preamp
i have 2 question from u
1-can i use 12.0.12 v instead 24.0.24 v?
2-how much is pp8 gain?
respectfully
Yes you can use +/-12V gain is 6dB
.....schematic for preamplifier with fet , terminal identified ... Sir Mile can tel us if I'm correct .
Alex.
Hi guys,
some of you have built this buffer?
Hi guys,
thanks mr mileYes you can use +/-12V gain is 6dB
how much is gain in pp12 and p30 preamp??
thanks mr mile
You can set gain with different value of feedback resistors, 6-10dB is usual value.
hello Apex,
you can drop below 6dB?
hello Apex,
Yes, but better to use buffer if you do not need gain.
OK ,
Any advise needed.
The SR60 (Olaf's) boards are filled with parts.
By viewing to 1837- hfe250-260 and 4793- hfe 220-230wish i have on hand, i feel they're not good matched, or could it work?
Is it necessary to have hfe more closed for better result- offset....?
It is ok, no need to be matched.
Both "1" and "2" are filters.mr mile
in circuit below which one caps are effective for filtrate voltage?
i have 40000uf but I don't know where puts
respectfully
Place the bigger ones in position "2", but do not remove caps from position "1" (you may use lower value ones, though).
Nice work, triac need small heatsink.
sir,i have on semi MAC228.Can i use MAC228 instead of MAC224 ??
What is amplifier's lower power supply voltage when this circuit used?Diy file...
Dear Apex Sir,
I am keen to make SR 200 Amplifier. Please advise whether to go with 4 pair BJT or 3 Pair for my PSU setup. Let me know if I need to change in PSU for this Transformer..
Toroidal - 55-0-55 , 1500 VA, 10 Amps
Capacitor - 60,000 uf / 100 v per channel. ( Total - 1,20,000 uf/ 100 volts)
Speakers - 10 inch Woofer - 8 ohms , 6.5 inch Kevlar Mid ( 8 Ohms) and Silk Dome ( 8 ohms)
Please guide me with suitable PCB link of SR 200 and PSU PCB link.
With Regards,
Samrat
With Regards,
Samrat
As someone who has worked in the broadcast and mastering industry for 35 years:
Studio quality/standard = what ever the studio decided to buy, nothing more!
Most of what I have seen is Crown and Bryston. But there are countless other brands in use.
QSC seems to be the commercial and color mastering theater amps of choice these days.,
P.S. Nothing against the Apex design. Looks good to me.
- Studio Reference Amplifier
