#101 |
Balanced input circuit is on separate PCB.
http://apexaudio.rs/ |
#102 |
apex..for psu regulator.If i supply 24 0 24 ac,it work or not?
#103 |
PSU regulator will work, just use 6,8V zeners instead 12V, and you can set output voltage about +/-30V DC.
#104 |
thanks.Can you design pcb for high quality amplifier for room like hifi sound using two 2sc5200 and two 2sa1943?I never seen your design using two 2sc5200.
#105 | |
#106 |
Beter is to use SR100 (cascode VAS) and add anothe pair of outputs
#107 |
#108 | |
APEX Studio Reference SR400 is very expensive amplifier , and I share only simple schematic for DIY.Regards
#109 | |
Regards Alex. |
#110 | |
Do You use heatsinks to connect colectors of BC639/640, BD241/242 to GND? Regards
http://apexaudio.rs/ Last edited by apexaudio; 14th November 2010 at 09:30 AM. |
| Crown Studio Reference I: beefing up the power supply | elac310 | Power Supplies | 4 | 28th April 2010 12:50 AM |
| Reference Amp for studio | exhausted mule | Solid State | 0 | 5th June 2006 05:39 AM |
| studio amplifier project? | rotation | Chip Amps | 2 | 2nd February 2006 04:33 AM |
| Any website reference for diy Audio Research REFERENCE amp and Manley Studio amp | bmpa | Tubes / Valves | 4 | 19th April 2004 05:11 AM |
| Any information , website reference for diy Hi-End computer studio sound card? | bmpa | Digital Source | 5 | 16th April 2004 04:57 PM |
