Studio Reference Amplifier
Old 2nd February 2013, 05:03 AM   #1071
Junie is offline Junie  Philippines
which version of PCB you use? Post some pics.
Old 4th February 2013, 06:11 AM   #1072
ahmadfay is offline ahmadfay  Indonesia
ahmadfay's Avatar
with this one...
Old 4th February 2013, 01:30 PM   #1073
mj777 is offline mj777  Australia
@ahmadfay,those are nonpolar capacitor
Old 5th February 2013, 12:31 AM   #1074
ahmadfay's Avatar
alright.
though with great difficulty I have got it. but I still can not set up the bias voltage, so that the final transistor gets hot, but I have a bias vr turn to the right and left. is there someone who can help me?
thanks
Old 5th February 2013, 01:01 AM   #1075
Arif Budiyanto is offline Arif Budiyanto  Indonesia
Hi Mas Ahmadfay...
As a common I set bias by measure v across R 0.33 Ohm. Set bias low first, let it run for couple days. When your amp survive then raise the the bias...Please always check the HS temperature...
Old 5th February 2013, 03:27 AM   #1076
ahmadfay's Avatar
ok Mas Arif, tak coba-e
this is brilliant idea,
thanks
Old 8th February 2013, 12:44 AM   #1077
marestiani is offline marestiani  Indonesia
I just made ​​SR50 and the sound is great, but the BF's transistor are quite hot when turned on for 5 minutes, is this normal or is there something wrong with the circuit that I created, help me please newbie here
Old 8th February 2013, 11:20 AM   #1078
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
Nice work, BF's must be hot, what is your rail voltage and what pcb design you use?
Old 8th February 2013, 11:53 AM   #1079
Thank you sir apex, i use 35Vdc rail voltage with 10A fake transformer the final transistor used A1943 - C5200 Grade II (only these sell in local store nearest my home) but the temperature not to hot and one more question if i use TL071 what do i have to change to the board? so hard find LF411 in here only got 5pcs last week, i used pcb design in attachment, thanks for sharing a good knowledge n schematic, this is my first build next i will build B500
Regard
Old 8th February 2013, 12:41 PM   #1080
apexaudio's Avatar
Regard
You can use TL071 instead LF411 without any changes.
Studio Reference AmplifierHide this!Advertise here!
Crown Studio Reference I: beefing up the power supply elac310 Power Supplies 4 28th April 2010 12:50 AM
Reference Amp for studio exhausted mule Solid State 0 5th June 2006 05:39 AM
studio amplifier project? rotation Chip Amps 2 2nd February 2006 04:33 AM
Any website reference for diy Audio Research REFERENCE amp and Manley Studio amp bmpa Tubes / Valves 4 19th April 2004 05:11 AM
Any information , website reference for diy Hi-End computer studio sound card? bmpa Digital Source 5 16th April 2004 04:57 PM
