I need to change the voltage output on connections I and J from +/-22v to +/-18v. I am having to change out the old Mitsubishi M5219L to a new OnSemi NE5532ANG. Suggested working voltage for the OnSemi device is max 20v. So in the power circuit I see there are a couple of Zener Diodes, ZD901 and ZD902, rated at 22v. Is it as simple as changing the Zener Diodes to 18v ones? I am assuming there needs to be a change in R905 and R906 value as well. Any help in providing values and solving my problem is deeply appreciated. Attached is a Jpeg of the Power Supply Schematic.
#2 |
hello.
volt drop across the base of bc546(bc556) is around 0,6v...........so you should measure 22,6v at the base. volt drop across r903/r904(39k) is 97v-22,6v = 74,4v and current through r903.......74,4v:39k=1,9ma. current through the 22v z-diodes should be around 4.......5ma (bc639/bc640 ignored) and the bc546b(bc556b) have a current gain(hfe) of 250 typically..........so only a tiny current of 4ma:250=0,016ma flows into the base of this transistors. if you change the 22v zd to a 18v zd........the factor is 22:18=1.22. so r905(r906) should be around 12k:1,22=9,8k.........so 9,1k or 10k should fit.......this is only estimated,not exactly calculated! and if you like you can increase r907(r908) to 15k x1,22=18k. it is late night here and i am listening to "the proms/bbc".........hope i am not totally wrong. greetings Last edited by mjf; 11th September 2010 at 10:10 PM. |
#3 |
........and perhaps r919(r920) increased to 2,4k...........2,7k.
annother idea is to connect z diodes (3,9v......4,7v/1,3w) in series with the outputs i,j.......... greets |
| Proton D1200 Advice | LHMAudio | Solid State | 4 | 9th May 2011 05:42 AM |
| Directed D1200 | mike49504 | Car Audio | 3 | 6th July 2010 01:34 AM |
| Viper (Directed) d1200.1 Supply Fet Problem | amc32 | Car Audio | 13 | 1st January 2009 03:14 PM |
| Viper (Directed) d1200.1 "Humpty Dumpty" | amc32 | Car Audio | 1 | 10th September 2008 05:16 PM |
| elan d1200 | vpolineni | Class D | 0 | 29th November 2007 04:53 AM |
| Page generated in 0.09044 seconds (76.70% PHP - 23.30% MySQL) with 11 queries |
