As titled, I have a batch of old jfets and need a quick method to know if any of them were dead other than using the usual Idss jig.
Thanks |
#2 |
Connect them as a diode.
Looks like Sponge Bob has killed another thread. |
#3 |
Check for a short circuit between gate and drain...
#4 |
If I can measure Idss on the jfet, does it mean it is working?
#5 |
I have the same problem as the OP about whether or not some JFETs are "dead", so your answer is very much of interest.
OK, so I check for a short between gate and drain - so if there is a short, it's blown, right? Or does a short mean that it's OK? If there isn't a short, does that mean the JFET is OK? Or are there other easy tests that can be done? I have heard that JFETs are very susceptible to being zapped from static. If this happens, what sysmptoms would a JFET display? Thanks, Andy |
#6 |
Generally, I don't believe JFETs are static sensitive to anywhere near the degree of MOSFETs - they are pn junction devices with no thin gate oxide to worry about. You'd need an impressive amount of static to kill a JFET.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
#7 | |
My problem is that I have soldered in a couple of JFETs and am getting a 0v reading from Drain to Source. So I am wondering why - it seemed to me that: a) I might have got the pins wrong? b) it might have been blown before I soldered it in place? c) I might've zapped it with static? So, as we can eliminate c), it seems likely I might have got the pins wrong? The JFETs are MPF102s. There is a cursive 'f' on the flat side - so I have assumed it must be a Fairchild, hence the pins are (from L to R, with pins down and looking at the flat side) D S G. Do you know whether this is correct? Regards, Andy |
#8 |
Andy,
You might have the D and the S interchanged? No, I'm wrong, you are right, here's the pinout from the Fairchild pdf, all is correct! Hugh MPF102pinout.gif Last edited by AKSA; 26th November 2010 at 08:55 PM. |
#9 |
#10 | |
I will replace the ones I have soldered in with some fresh ones ... as it looks like they are kaput! Trouble is, perhaps the whole batch I was sent (16) is all kaput? I need to be able to test them before I go to the trouble of soldering them in.Would measuring the Idss first, "prove" they were OK? Regards, Andy |
| Speaker Workshop - using "Measure -> Passive Components" to measure ESR ? | percy | Multi-Way | 0 | 12th March 2006 09:18 PM |
| Simple Method To Measure Source Resistance? | kelticwizard | Tubes / Valves | 21 | 27th December 2005 05:49 AM |
| Can I replace BF245C JFET with J201 JFET? | bigmike216 | Parts | 2 | 7th December 2005 06:50 AM |
| quick! look, another dead car amp thread!! :D | Tensop | Car Audio | 10 | 2nd October 2004 04:50 PM |
| How do you measure Vas by added mass method? | Circlotron | Multi-Way | 1 | 28th December 2002 08:11 PM |
| Page generated in 0.11714 seconds (77.03% PHP - 22.97% MySQL) with 11 queries |
