can a ss amp suffer degradation in performance through accidents? can a ss amp suffer degradation in performance through accidents? - Page 2 - diyAudio
Old 5th September 2010, 11:15 PM   #11
unclejed613 is offline unclejed613  United States
unclejed613's Avatar
there are a few possibilities here:
1) however unlikely, the preamp somehow damaged the input stage of the amp (both channels with the same failure at the same time is very unlikely, but possible.
2) an outside source of the behavior of both the preamp and the amp, such as an RF source. this is something that should be investigated.
3)something in the power supply of the amp causing the noise. amps of that vintage used transistor regulators with a zener reference. one source of noise here is the bypass cap for the zener drying out, and the regulator transistor amplifying and passing the avalanche noise along to the regulated supply.
4) the diff amp transistors, being 30 years old are beginning to show signs of aging, which in early stages shows up as noise.
5)catastrophe theory. the noise was always there, and the OP never noticed it before another failure (the bad behavior of the preamp) called his attention to it. this still doesn't rule out number 2, 3, or 4
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net
spammer trap: spammers must die
can a ss amp suffer degradation in performance through accidents?Hide this!Advertise here!
new technique to measure audible distortion and signal degradation Kulish Mikhail Software Tools 8 13th April 2010 09:10 PM
do mosfets suffer from magnetic fields pointy Solid State 2 7th March 2010 03:31 PM
I need a simple ss reverb for a ss guitar amp. yeto Instruments and Amps 8 18th January 2006 06:54 AM
Would the active crossover suffer chris ma Everything Else 1 3rd July 2004 06:02 AM
TOSLink Cables All the same? Any degradation over Length? Schmanthony Digital Source 58 21st September 2002 07:33 PM
Copyright ©1999-2017 diyAudio
