LM4780 stereo Power-amp PCB design
Old 28th August 2010, 09:04 AM   #11
thepcman is offline thepcman
Ok how about this one then?
Old 28th August 2010, 11:55 AM   #12
for effective attachment of the heatsink the Chipamp should be at or near the edge of the PCB.
The decoupling caps C6 C1 have a very dirty current between their Zero Volt pins.
Do Not place any Ground Reference on this linking trace.
Why is V- separate from V+?
Look at the route from pin4 to C5 to C2 to pin9. That route must be at least 10times the length of the route from pin 4 to pin 9. That type of routing can be avoided by using the single amp version, lm3886.
regards Andrew T.
Old 28th August 2010, 12:56 PM   #13
V- is a bit apart from V+ so that i can keep up with star ground with the single layer PCB, the real distance is 1 inch (2.54 cm)
You are correct that C1 & C6 are very distant, for that reason, i placed C2, C3, C4 and C5 as close as possible to IC, they have the values 10u and 100n.
I did not understand the idea behind the route length constraint you said, can you explain the reason please?
Meanwhile i will try a bridged version
Old 28th August 2010, 12:57 PM   #14
donpetru is offline donpetru  Romania
donpetru's Avatar
Is not good as you used jumpers behind LM4780. There must come amplifier heatsink and should not sit on jumpers. Is not good. Try again or pay someone to do it.
Regards.
AV400v2 and GX400 audio amplifier projects
PCB Design Services - for prototypes OR serial products, Today Tehnium and Forums
LM4780 stereo Power-amp PCB designHide this!Advertise here!
Power Amp PCB design, grounding prairiemystic Solid State 77 6th July 2010 01:48 PM
LM3886 stereo - PCB design Razor_x Chip Amps 2 3rd July 2009 01:18 PM
LM4780 Bridged PCB Design Gcollier Chip Amps 3 14th February 2005 02:50 AM
LM4780 PCB power transformer Jim Karr Chip Amps 1 6th January 2005 07:29 PM
LM4780 PCB Design Thoughts Gcollier Chip Amps 0 4th March 2004 06:51 PM
