Class AB amp made by me.
Closed Thread
Old 27th August 2010, 01:17 PM   #21
megajocke is offline megajocke  Sweden
megajocke's Avatar
AndrewT,
his protection circuit removes the drive before the "VAS". It's not of the usual type that shorts out the drive to the output stage after it.
Old 27th August 2010, 01:32 PM   #22
DjLeco is offline DjLeco  Romania
Originally Posted by megajocke View Post
AndrewT,
Perfectly observed!
Old 27th August 2010, 02:34 PM   #23
donpetru is offline donpetru  Romania
donpetru's Avatar
@DjLeco, diagram overload protection I think like with the diagram below called amp.jpg (I could even say almost the entire amplifier, perhaps with some small differences, the number of output transistors...).
I have attached below block diagram drawn by you where I framed with red some resistors. What value are the currents through those resistors?
I ask this because that current values are important for proper functioning of the amplifier. DC balance of the input differential pair is essential in power amplifiers. It still seems almost unknown that minor deviations from equal Ic in the pair seriously upset the second-harmonic cancellation. So, imbalance also reduces the open-loop gain if serious enough. Treat this issue very carefully.
Regards.
AV400v2 and GX400 audio amplifier projects
PCB Design Services - for prototypes OR serial products, Today Tehnium and Forums
Old 27th August 2010, 02:45 PM   #24
Donpetru,checkPM.
Old 27th August 2010, 04:44 PM   #25
Please someone calculate aproximative Damping Factor
www.youtube.com/watch?v=24pfrHL93qk
www.youtube.com/watch?v=9VBFspvUOv4
www.youtube.com/watch?v=eabMHBY4mEo
Damping on speakers:
www.youtube.com/watch?v=pv2LQuZOVbQ
Nice movie!
www.youtube.com/watch?v=PsJER9dxxGc
Old 28th August 2010, 08:37 AM   #26
donpetru's Avatar
If you want to calculate practical the damping factor, follow instructions from there (they is not pretty accurate but... works!):
Damping Factor with Calculator
On the other hand, damping factor is of two types:
1. Rated Damping Factor = RDF (as shown in the calculation of the site posted above). This damping factor is calculated based on laboratory test conditions which have little connection with actual operation of the amplifier.
2. Effective Damping Factor = EFD (more accurately describes the interaction between a real amplifier and a real speaker). So, when we calculate the EDF of an amplifier, it is absolutely necessary that we include this DC resistance into the damping factor expression. For example, if the actual impedance of the speaker may be 4 Ohms and we measure the voice coil of this speaker, we will probably find that it has a DC resistance of about 3 Ohms. Then, there must be taken into account the impedance of the speaker resonance (which can reach and the 40 ohm). We need to take account of this, because at resonance, speakers typically are very uncontrolled and have the least mechanical damping. So this is damping factor, I tell you... is real (and usually is much smaller than RFD).
Later edit: Remember that all, any amount of damping factor is affected by power supply amplifier characteristics. Design well the power supply to have a high damping factor.
Regards.
Old 28th August 2010, 08:49 AM   #27
I konow that link with DF calculator.
And yes a speaker with impedance of 4 ohms, have coil resistance(in ohms) between 3,2 and 3,8 ohms, but it varies alot at resonance freq of speaker...
Old 4th September 2010, 05:01 AM   #28
hadita is offline hadita  Indonesia
hadita's Avatar
hello DjLeco,..i'm interest to build this power designt from you please share the schematic and list of component to my email hadita_adit@ymail.com)
thanks
Old 4th September 2010, 07:03 AM   #29
ostripper is offline ostripper  United States
ostripper's Avatar
Why all this movie stuff ?? Just post the schematic.
Just a full complimentary topology (another one), would just be interested in how YOU do it , add knowledge to all the other versions ?
OS
Wanderer - my travels.... Facebook - davyjones lockre -
Old 4th September 2010, 10:01 AM   #30
It's a full complementary design, perfectly simmetric.
Sorry for not sharing schematic, that is MY prototype, I go from a simple schematic, developed till here.
Closed Thread
Class AB amp made by me.Hide this!Advertise here!
Class AB, Class AB Non-Switching, Class AB Soft Non-Switching steph_tsf Solid State 4 15th March 2010 03:39 PM
Configuring an AB class amp to work in pure A class jrme Tubes / Valves 5 23rd February 2010 06:31 PM
mosfet class a/ab amp p robertson Solid State 30 9th February 2010 11:07 AM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 07:52 PM
tweaking a class AB amp blunt Solid State 49 24th March 2007 01:59 PM
Copyright ©1999-2017 diyAudio
