Old 23rd August 2010, 07:47 AM   #1
Default simple ne5532 and irf630
I construction a simple amplifier,none capacitor,feel sound well,someone give me some advice,my english very poor,hope everyone understand,~~haha~~
in fact,i use irf630 instead of irf610
Old 23rd August 2010, 11:47 AM   #2
lineup is offline lineup  Sweden
lineup's Avatar
Hello.
I use MultiSim, too.
I tested your circuit. It works well.
What I should change.
1. I should use +-18V Supply
2. Use NE5534P. Is a better opamp than NE5532
And you can build two channels separate. Dual Mono blocks.
3. IRF630 is better. 74 Watt. IRF610 only 36 Watt.
Myself, I should go for IRF540N/IRF9540N. More than 100 Watt
Here is my variant. No longer as simple as your. But it is not very difficult.
It gives max 14 Watt RMS into 8 Ohm
By using 2 BOOTSTRAP capacitors we help opamp to give higher volt out.
One thing to fix is the DC offset: -115 mV
This can be done using Pin1 and Pin5 of NE5534
lineup
Old 23rd August 2010, 03:30 PM   #3
lineup's Avatar
Sorry.
To fix DC Offset we use Pin1 and Pin8 of NE5534.
lineup
Old 24th August 2010, 02:16 AM   #4
First thanks your advice,In reality,some little diffefrence to above,in output I add 2 capacitor(1000uf+1000uf) of one channel,protected my speaker,extra advantage is reduce current, i guess bass may be affect
Old 24th August 2010, 02:22 AM   #5
I see your circuit,don't understand your 220Ohm,drop it may be better,add to opamp drive current
Old 24th August 2010, 02:38 AM   #6
By my test,I feel two mosfet little diffrence submerged in feedback,someone agree with me?
Old 24th August 2010, 10:51 AM   #7
RLa is offline RLa
You have to add bias management circuit for the output stage otherwise the circuit will end up in thermal runaway.
Old 24th August 2010, 12:24 PM   #8
lineup's Avatar
Gate-stopper values ?
220 Ohm at GATE of MOSFET is to prevent oscillation.
They are used very often and we call these resistors Gate Stoppers
You can find them resistors in almost every MOSFET amplifier.
lineup
Old 24th August 2010, 12:35 PM   #9
Attachment 185012
Dear LoveVirus,
Why not use the NE5534 instead and drive the output stage from pin 5? Basicly you drive them direct from the NE5534 VAS which will be in class A.
With kind regards,
Bas
Old 24th August 2010, 01:02 PM   #10
Dear Lineup,
Doesn't that increase the distortion of the NE5534? I remember some older measurement I made that distortion rise if you go above approx. 50mV, by miss balance the input transistors in the NE5534
With kind regards,
Bas
sound of mosfets IRF630 vs IRF610 intense-tavda Pass Labs 3 1st November 2006 07:46 PM
What to do with IRF630...have some idea to help me? destroyer X Solid State 8 2nd August 2006 01:44 PM
WTB: IRF610, IRF630, ZTX450 and ZTX550 folkeb Swap Meet 0 1st July 2006 10:44 PM
powersuppy for BosoZ with IRF630 and IRF9610 Merijn Pass Labs 2 11th November 2003 11:23 AM
Page generated in 0.09127 seconds (85.55% PHP - 14.45% MySQL) with 11 queries
