End Millennium Pseudo-clone Amp
Old 21st August 2010, 09:59 PM   #1
Havenwood is offline Havenwood  Argentina
Havenwood's Avatar
Send a message via MSN to Havenwood
Default End Millennium Pseudo-clone Amp
Hi, I build this pseudo-clone amplifier.
What do you think?
When I finish my function generator based in XR2206 I upload some pictures from my old oscilloscope.
The amplifier sound really good, Iq = 70mA and gain x10 (or 20dB).
I use hyper-common componets, like BC547/557, BD139/140 and TIP3055/2955 TO3P.
For minimize the noise, in a few days, I hope finish the VAS and input stage power supply. Use voltage doupler (i donīt want use another transformer) and capacitance multiplier, like various japaneses amplifiers.
Cheers
- Music by John Williams -
Old 21st August 2010, 11:46 PM   #2
lineup is offline lineup  Sweden
lineup's Avatar
I like it.
Symmetrical input and VAS.
Triple Darlington output .. light load for the VAS. Easy to drive,
R17 and R18.
With 10k it makes the gain in VAS only x10 (10k/1k)
You could make them 100k.
Experiment. Because this will effect the THD dist.
You can even run without R17/R18. This is the normal for maximal gain.
lineup
Old 22nd August 2010, 06:23 AM   #3
Havenwood's Avatar
Here is the positive Vreg, from the main transformer.
Voltage doupler + Capacitance Multiplier.
Rippley is very low under low load (100omhs). When I finish the function generetor, I test this PSU on the amplifier.
Iīm working in the PCBs of all.
1N4148 = 1N4007 (in pspice is missing)
BF469 = BD139
BZX.... = Zener 24V
Old 3rd October 2010, 05:53 PM   #4
Havenwood's Avatar
Hi, after read some threats, what is the impact to use cascode current source? only provides more Zout?
And Sziklai pair on input stage?
Anybody build some amplifier with CFP input stage?
Old 4th October 2010, 02:07 AM   #5
djk is offline djk
djk's Avatar
"You can even run without R17/R18. This is the normal for maximal gain. "
With no global feedback the gain would be a bit too high don't you think?
The first stage has a gain of about 6dB, the second stage about 20dB, 26dB is about the right gain for a hi-fi power amplifier.
Candidates for the Darwin Award should not read this author.
Old 10th October 2010, 05:41 PM   #6
Havenwood's Avatar
I donīt measure Zout, but is valid use configuration to reduce Zout?
End Millennium Pseudo-clone AmpHide this!Advertise here!
anyone knows about Millennium XP amp? space2000 Solid State 0 15th May 2008 12:58 PM
millennium 2.4.6 troubles mpmarino Digital Source 0 29th June 2006 02:02 AM
schematic for the End Millennium bigpanda Solid State 1 17th February 2006 01:05 AM
pseudo horn ?? ChesterFuzzin' Multi-Way 3 6th April 2004 06:57 AM
Copyright ©1999-2017 diyAudio
