Old 20th August 2010, 10:31 PM   #1
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Default Who invented Diamond Buffer?
I remember some debates last year about Diamond Buffer, as if it is a state-of-the-art thingy designed by modern IC designers...
Today I've found an ancient Telefunken paper with schematic that contains a discrete opamp with Diamond buffer output:
http://www.irt.de/IRT/publikationen/braunbuch/V676B.PDF
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 20th August 2010, 10:57 PM   #2
AKSA is offline AKSA  Australia
Anatoliy,
I understand it was used by Radford in their Z series amps in the late sixties?
But it's such a basic building block I'd think it was around in the mid-fifties, surely?
Hugh
Aspen Amplifiers P/L (Australia)
www.aksaonline.com
Old 21st August 2010, 12:41 AM   #3
lineup is offline lineup  Sweden
lineup's Avatar
Yes, it looks like it was in the sixties.
And by that time and in 70-ies amplifier started be symmetrical.
Here is from internet:
The lineage of the Diamond Buffer can be traced to the Classic national semiconductor Line of Hybrid Buffers starting with the LH-0002. and continuing with an apparent never ending line of newer products. From the LH-0002 was introduced in 1968. From 1979 is AN-227 this denotes the applications of the LH-0002 and provides technical details of its operation.
Applications of Wide-Band Buffer Amplifiers
http://www.national.com/an/AN/AN-227.pdf
Webpage: Essential Data Sheets, Schematics and App Notes - Head-Fi.org Community
lineup
Old 21st August 2010, 03:00 PM   #4
StevenOH's Avatar
<<But it's such a basic building block I'd think it was around in the mid-fifties, surely?>>
Clearly, not before good complementary bjt were developed
Interesting R31 ac bootstrap (Telefunken).
The truth is out there. Who can handle the truth?
Old 21st August 2010, 03:08 PM   #5
AndrewT is online now AndrewT  Scotland
since so many of these classic circuits originated from tube/valve days, is there a way to implement a diamond buffer using our single sex tubes/valves?
regards Andrew T.
Old 21st August 2010, 03:12 PM   #6
PMA is offline PMA  Europe
PMA's Avatar
There is a subtle problem - there is nothing like P-valve
Pavel Macura, consultant
http://cz.linkedin.com/pub/pavel-macura/4/783/637
Old 21st August 2010, 03:17 PM   #7
I know, that's what single sex implies.
Transformers are traditionally used to overcome the lack of Pdevices
But is there a transformer less way to implement the diamond buffer with tubes/valves.
If there is, then that may give a clue to the date of origin.
regards Andrew T.
Old 21st August 2010, 05:50 PM   #8
Juergen Knoop's Avatar
probably named after mr.diamond and his amplifier circuit:
"An Adjustment-Free Complementary Power Amplifier" by J.Diamond
regards
Old 21st August 2010, 07:57 PM   #9
Elvee is offline Elvee  Belgium
It could look something like this.
But it defeats the main advantage of the diamond, mainly taking care of the dc voltages easily and efficiently.
With tubes, you need voltage translations using capacitors or similar devices.
I doubt something like that has ever been used (4 tubes! enough to build a complete radio set)
Diamond Buffer - Super Buffer peranders Solid State 34 16th May 2010 01:46 PM
Diamond buffer in PIMETA slowpogo Chip Amps 3 19th April 2007 05:58 AM
what about diamond buffer MOSFET? padamiecki Solid State 26 5th October 2005 03:55 PM
Diamond buffer peranders Solid State 45 15th November 2003 11:00 PM
Page generated in 0.09859 seconds (86.77% PHP - 13.23% MySQL) with 11 queries
