Hey can anyone direct me to a site that sells onboard amps? I'm looking at building a few subs with this driver,
Ryda Car Audio - JBL GTO1514 15" Car Subwoofer($194.85) I just wanted to know if it'd be any where near as economical as building them passive and getting one big amp to power them Cheers in advance |
#2 |
what supply voltage is available?
Is it 12Vdc or 13.8Vdc or 110/120Vac or 220/240Vac?
regards Andrew T. |
#3 |
We have 220-240V/50Hz down here, I hadn't thought about that!
#4 |
many sell "plate amps" specifically to attach to bass speaker cabinets.
They usually have extra EQ & filters to dial in the bass response needed.
regards Andrew T. |
#5 |
Ok thanks I'm searching for plate amps now, I'm familiar with a fair bit of audio gear but I wasn't even sure what onboard amps are called!
#7 |
Cheers djk How would these amps run in a pro sound application? i.e. full power for extended periods..
#8 |
definately not.
regards Andrew T. |
#9 |
Any ideas on where to find tougher gear?
| new Battery powered TK2050 Amps! 2 right now, I might build more later. | gripracer | Swap Meet | 18 | 31st January 2011 08:15 PM |
| regulated power supply for high powered amps. | marchel | Solid State | 14 | 5th March 2009 09:00 AM |
| Speakers for Flea Powered Amps <1.5W | bloozestringer | Tubes / Valves | 2 | 17th November 2008 05:17 PM |
| DC powered amps | Carlp | Tubes / Valves | 11 | 9th July 2006 06:25 PM |
| Page generated in 0.10466 seconds (77.77% PHP - 22.23% MySQL) with 10 queries |
