diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Solid State (http://www.diyaudio.com/forums/solid-state/)
-   -   Good p-channel substitute for 2N5457 needed (http://www.diyaudio.com/forums/solid-state/171903-channel-substitute-2n5457.html)
Test Electrix 14th August 2010 04:15 PM
Making a circuit with a positive ground using this schematic here as a starter though the one that would be in uses a positive grounding path so I don't think the N-channel 2N5457 would be suitable, any suggestions for a replacement? Wikipedia says 2N5460 though as they have different characteristics I am unsure.
Any help would be greatly appreciated!
CBS240 15th August 2010 06:33 AM
Goss and Vgs of the 5460 is a bit larger than 5457. Maybe increase bias current or add an extra series diode or two to make the difference?
Resources saved on this page: MySQL 18.75%
