Old 14th August 2010, 10:01 AM   #1
Default A very interesting amplifier schem , do someone knows more about??
Hello
Here is a amplifier schematic , for 2 different type power mosfet or to the new Sanken darlington .
Do someone know more about these ?
Any comment welcome since only the schematic and a couple words ,to me looks like Japanese .
Sorry if already somebody ask about these , I didn't find any info on the forum.
Please take a look .
Greetings
Old 14th August 2010, 10:21 AM   #2
wahab is offline wahab  Algeria
These are device with integrated diodes for thermal tracking.
They are at least 10 years old.
Elektor did use them in a few designs..
Old 14th August 2010, 10:50 AM   #3
Interesting front end!
Old 14th August 2010, 04:41 PM   #4
Hello
Yes the front end I think a bit over complicate but can be still good .
The output section actually very nice .
Probably for a few watt biased in class A or all the way ? 40V PS and 3 pair high power mosfet or darlingtons .
I was curious if anybody tried to clone these . Or the front end to scary?? It seems to me a bit over "the limit" .
Greetings
Old 14th August 2010, 05:14 PM   #5
Well, the front end is probably good thanks to its relative complexity. I´m willing to try simulating it and if I can get it stable in the simulator I might build it and pair it with Cordell´s error correction output stage.
Old 15th August 2010, 08:09 AM   #6
CBS240 is offline CBS240  United States
CBS240's Avatar
Not too complicated at all, cascodes with J-fet CCS's to set the cascode voltages and the current sources for the LTP legs, the VAS mirror is also cascode. The difference in current from the sum of the two LTP leg sources and common mode current source at the bottom for both sides drives the VAS. Quite a neat arrangement I think.
All the trouble I've ever been in started out as fun......
Old 15th August 2010, 08:48 AM   #7
ostripper's Avatar
Front end looks like Roender's "RMI" folded cascode. Only difference is the FET CCS for the cascode references. Another neat thing ... it looks like a modular setup , plug in any output stage. #1 is P-N vertical 2- quasi vertical 3 - a mystery?? (proprietary **)
OS
Mongrel website , always current and updated :
http://67.248.209.21/D%3A/WEBSITE/
Old 15th August 2010, 09:10 AM   #8
ostripper's Avatar
Originally Posted by gaborbela View Post
Hello
Greetings
Maybe if you compare it to a DX. It is just a slighty augmented "symasym"... I might sim it and put it on a 75mm X 75mm PCB module , just for fun (HX "mongrel").
OS
Old 15th August 2010, 09:49 AM   #9
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via MSN to abraxalito Send a message via Yahoo to abraxalito Send a message via Skype™ to abraxalito
Chinese I think. A couple of points - don't follow the input wiring arrangement shown - decoupling to the input ground (unless you want fairly poor sound). And the output stages have the zobel network on the wrong side of the output choke. According to Doug Self, the zobel is to help suppress VHF parasitics in the output stage, putting it on the far side of an inductor will reduce its effectiveness at that.
I think ideas are what you want to get rid of. I don't really like songs with ideas. - Leonard Cohen
Old 15th August 2010, 10:01 AM   #10
ostripper's Avatar
That is probably a HF input filter (220-470pF) OUR (DIY) zobels are standard ..
I don't think this was meant to be built , just an overview of some chinese design with a separate more specific BOM.
OS
interesting amplifier schematic lt cdr data Solid State 2 14th May 2009 04:35 PM
Help to understand this schem please! apr Instruments and Amps 11 1st January 2009 08:06 PM
help, schem for sherwood psychosteve Solid State 0 10th November 2004 05:35 PM
Interesting Gainclone type amplifier? misterresistor Chip Amps 23 29th April 2004 10:11 PM
Interesting amplifier thylantyr Solid State 0 3rd March 2003 08:33 AM
Page generated in 0.11978 seconds (77.86% PHP - 22.14% MySQL) with 11 queries
