Old 12th August 2010, 02:27 PM   #1
comasus is online now comasus  India
Default 100-watt sub woofer amplifier
Hello
see the attachment
The output transistors getting hot very much Q7 is getting hotter than Q5
could you please tell me how can i reduce heat
Old 12th August 2010, 03:33 PM   #2
AndrewT is online now AndrewT  Scotland
check for oscillation.
If it is bad it will destroy your project.
I don't see an output Zobel.
I don't see an input RF filter.
that increases the risk of oscillation.
What is the output offset?
Have you tested the amplifier into an open circuit and into a 8r0 resistor?
Have you shorted the input to signal ground for these tests?
C1 & C2 don't look right for a sub-bass amplifier. They might just about work as a high pass filter for a bass amplifier.
I would prefer to see a separate pre-amp to tailor the signal to suit the speakers.
That would then leave the amplifier to pass all bass frequencies it receives on to the speaker.
regards Andrew T.
Old 12th August 2010, 05:09 PM   #3
Dear sir
I am new to electronics could you please guide me
How can i change this to normal amplifier so that i can use this for keyboard
in the circuit diagram Q1 and Q2 are shown as bc108 but i have used mpsa42 and i am giving +/-45v supply
Old 13th August 2010, 07:23 AM   #4
ostripper's Avatar
Originally Posted by comasus View Post
Dear sir
Here is one that will work with your mpsa42's and will be 10 times better that the one you posted. Runs on 40-0-40vdc.
OS
Mongrel website , always current and updated :
http://67.248.209.21/D%3A/WEBSITE/
Old 13th August 2010, 08:26 AM   #5
Thank you but i want amplifier using the transistor 2n3773
Old 13th August 2010, 08:47 AM   #6
Thanks but i want an amplifier using 2n3773
Old 13th August 2010, 10:28 AM   #7
lineup is offline lineup  Sweden
lineup's Avatar
As AndrewT said, it is probably oscillation.
The lower output, Q6, Q7, is in fact a CFB, Sziklai.
In this Quasi output stage.
My guess is that Q6-Q7 are oscillating.
I would try first with a capacitor (can be ceramic) 100pF
between B, Base, and C, Collector pins of transistor Q6.
If this does not help I would try with 220pF or 470pF.
lineup
Old 13th August 2010, 10:39 AM   #8
sakis is offline sakis  Greece
sakis's Avatar
you need to verify the idle current of the amplifier ...that is measuring on the R14- and R16 the voltage drop ( carefully there you are looking at millivolts range )
if then this high means that your amplifier idles in higher bias than it supposed to be
the reason for that is the poor vbe multiplier that exists on this circuit ....
to make this in plain greek there is a string of diodes D1 and D2 that are supposed to be in perfect physical contact with the heat sink of your amplifier carefully now cause you need good physicaL contact but absolutelly no electrical contact
While your amplifier operate temperature goes up ( that is why you need a good heatsink ) together with the temperature also idle or biass goes up all the above drive your amp to a think called thermal run away .... to avoid this the D1-D2 while attached on the main heatsink will sense and monitor temperature and reduce bias to avoide thermal run away
of course the two transitors need insulation from heatsink and most imortand proper heatsink .... proper means a quiet big size ...
check all these and get back to us also post pictures of your work might also help
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 13th August 2010, 11:28 AM   #9
voltage drop at R14 is 23mV at R16 is 54mV
Old 13th August 2010, 11:53 AM   #10
what have you got connected to the output?
Those different voltages across Re indicate massively different currents.
Where is that difference in current going to?
Back down the NFB connection? Check the resistor you have fitted.
Check Re resistances.
regards Andrew T.
Sure electronics 4*100 watt @ 4ohm, TK2050 D-class Audio Amplifier Board aquapiranha Class D 3 30th May 2011 11:06 PM
Modifying 100 watt LXI amplifier circuit CrazzyAbtTubes Solid State 19 30th November 2009 01:17 AM
100 watt audio amplifier kibet85 Solid State 24 21st August 2008 10:55 AM
100 Watt AMP ali_moinuddin Swap Meet 1 30th December 2007 05:26 AM
350 watt amplifier for sub-woofer Phile75 Car Audio 10 7th July 2004 03:14 AM
Page generated in 0.11311 seconds (76.19% PHP - 23.81% MySQL) with 11 queries
