Hello!
Anyone tried to replace bias diodes which are hard to mount with TO-220 transistors in B-E connection? That will be easier to use with "normal" heatsink. |
#2 |
I've done that for other amps in the past (not the Leach). Works well. It is definately more convenient...
mlloyd1 |
#3 |
You mean use of standard Vbe; one transistor mounted on heatsink. I was thinking to change diodes in series with transistors connected b-e in series.
#4 | |
Account Disabled
#5 | |
Electrons are yellow and more is better!
/Per-Anders (my first name) or P-A as my friends call me |
#6 | |
Banned
I like the idea of having the Vbe multiplier on the circuit board to minimize stray capacitance to ground from the output of the second stage. This leads to better stability. Remember, the second stage sets the dominant pole in the open-loop transfer function. I don't want that transfer function to be a function of unpredictable wiring capacitance to a Vbe multiplier on the heat sink. Therefore, I opted for the diodes on the heat sink. The stray capacitance of the leads to the diodes can be isolated with series resistors. You can't use the series resistors if you put the Vbe multiplier on the heat sink. |
#7 |
diyAudio Moderator Emeritus
The diodes aren't that difficult to deal with. Just put them on the heatsink near your devices. Here is a picture of the latest leach amp that I helped a friend build, using newer MJL1302A/3281A devices.
-- Brian |
#8 | |
#9 | |
Douglas Self recommended to put the diodes to the top of the output devices. This gives better sensitivity, and less capacity, due the large distance from the heatsink. Sajti |
#10 |
'Anyone tried to replace bias diodes which are hard to mount with TO-220 transistors in B-E connection? That will be easier to use with "normal" heatsink.'
i actually use the base collector junction, yes it can be done, i find them to be more siensitive due to the nature of construction of the transistor, i use case 77 types mostly.... |
| Floating Bias in Leach vs. Slone ?? | sam9 | Solid State | 20 | 17th March 2004 02:56 PM |
| Where to put diodes on Leach amp? | supernet | Solid State | 5 | 16th April 2003 06:53 PM |
| Leach Amp bias/star ground questions? | hard times | Solid State | 2 | 14th September 2002 02:30 PM |
| Leach Amp bias current (what is yours set to?) | BrianGT | Solid State | 3 | 21st February 2002 08:53 AM |
| Page generated in 0.11730 seconds (78.05% PHP - 21.95% MySQL) with 11 queries |
