I'm constantly collecting parts for varous projects that I'm interested in. As you might have guessed, I'm interested in music and its reproduction. I like to try my hand at building a decent amplifier, something that'll perform above and beyond a Marantz PM17 I'm using.
I salvaged a couple of large heatsinks amongst other things from a ups, about the size of a small fridge, the single width type that fits below kitchen work/counter tops. It was designed to used with fan cooling and probably could dissipate hundreds of watts easily. There are 27 power transistors mounted on it ! I'd like your opinions on whether they're capable of dissipating about 150W heat with a temperature rise of no more than 40 degrees in free air. I'd like to avoid using a fan. ![]() ![]() ![]() Full size ones here http://yfrog.com/b9p1140959j http://yfrog.com/jtp1140960j http://yfrog.com/79p1140954j http://yfrog.com/74p1140955j http://yfrog.com/jtp1140956j http://yfrog.com/79p1140957j Thanks fs Last edited by firestorm; 9th August 2010 at 09:24 PM. Reason: For some reason I can't get the thumbnails to expand to full resolution ... |
#2 |
It must be the some what dry title, does it help if I chose to use something like "Super size me heatsink for Class A Monster Amp"?
#3 | |
Those units look about as big as 2 of the 8 heatsinks on my genesis chassis. I am using no fan with a 225w amp on just those 2 and never even get close to 40c under normal conditions (25c ambient). I have no AC , and ambient is close to 37c (97F) today , but the heatsinks are only just at 40C. OS
Mongrel website , always current and updated : http://67.248.209.21/D%3A/WEBSITE/ |
#4 |
Hi OS,
thanks for the input, I was feeling a little left out ;-) I need to work on americanizing the title I use ![]() I'm considering building the DC Moskido, Aikido tube front end with class A pp mosfet power section. I've got two of these sinks, so I should be ok, theres around 150W x 2 to get rid of, depending on what bias current I choose. Cheers fs |
#5 | |
OS
#6 |
Great, now the small matter of which amp to build now !
I'm considering : 1) Moskido (Aikido tube driver, pp class a mosfet power section) 2) JLH 96 (BJT pp class a) 3) ?? The JLH is a simpler implementation due to just the single bipolar psu. The Moskido needs a HV psu for the tube driver, although it is possible to use low voltage tubes and 24v B+. I might just start a new thread, as the title is just too boring :=) Thanks for your help OS |
| calculate thermal resistance of alumimium heatsink | bigpanda | Everything Else | 1 | 17th September 2008 09:14 AM |
| Thermal Resistance of 2sc5200 | goodlife | Parts | 2 | 21st April 2005 09:41 PM |
| heatsinking and thermal resistance | theChris | Parts | 7 | 2nd April 2003 06:35 PM |
| Thermal resistance of L-profile | BoGoMiPz | Solid State | 0 | 31st October 2002 11:52 AM |
| Heatsink: Thermal Resistance Vs Length | vinay | Pass Labs | 5 | 15th October 2002 03:09 AM |
| Page generated in 0.09739 seconds (77.31% PHP - 22.69% MySQL) with 10 queries |
