Old 9th August 2010, 06:17 AM   #1
panson_hk's Avatar
Default Criteria for well behaved clipping
What are the key criteria for well behaved clipping for solid-state amps?
Here are plot for Sansui AU-a607MRX integrated amp clipping behavior for 100 Hz, 1 kHz and 10 kHz. The load is a dummy 8 Ohm resistor. This amp was so-called hi-end integrated amp from Sansui. However, its clipping behavior is nasty.
Old 9th August 2010, 02:35 PM   #2
jcx is offline jcx  United States
looks like fold-back current limiting at low frequency and clipping isn't your 1st problem at 10 KHz - you are hard slew rate limiting there
you could clip the input signal at a V that keeps you below the current limit
basically just keep the signal input at a low level that wouldn't give current, slew rate limiting - using just a fraction of the rated power
Bob Cordell Interview: Error Correction (maybe now that his book is out we'll see the Klever Klipper?)
Collated Design Criteria/dimensions for Ariel ML-TL Design talsius Full Range 1 13th October 2011 05:28 AM
Recovery from clipping, soft clipping hahfran Solid State 49 23rd February 2010 01:03 AM
se, srpp, pcb design criteria Electroshocked Tubes / Valves 13 1st July 2009 08:20 PM
Reconstruction filter design criteria. Aiace Digital Line Level 2 18th April 2009 09:06 AM
Drivers selection criteria. beppe61 Multi-Way 8 19th April 2006 04:18 PM
Page generated in 0.08402 seconds (58.94% PHP - 41.06% MySQL) with 11 queries
