Problems with P3A after refitting
Old 30th June 2003, 10:29 AM   #1
Cradle22 is offline Cradle22  Germany
Cradle22's Avatar
Default Problems with P3A after refitting
Hi!
I have been refitting my P3A with new resistors (RC55) and one of side with new power devices (MJ15003/15004) and new VR1, since I killed them due to slipping probes (I had connected the collector of Q7 to ground).
The side without new power devices works well, but the one with new transistors doesn't.
Tests like Rod describes with 22 Ohm resistors are OK, +- 42 V on the rails, 4 mV dc offset
But then measuring voltage across the 0.47 ohm resistors (which should be about zero), I measured 38 V across R13... as well as between the collectors of Q7 / Q8
Then I also exchanged all other transistors (the BD139/140 and BC546 types), and measured again. Voltage across R13 went down to 9.3 V, as well as between collectors Q7 / Q8, but still way too high.
Amazingly nothing gets really hot.
Has anyone an idea of what to look for? I resoldered everey solder joint, checked for shorts, did not find anything...?
Bye,
Arndt
A Sacrifice For Freedom
Old 30th June 2003, 10:38 AM   #2
Audiofanatic is offline Audiofanatic  Netherlands
Audiofanatic's Avatar
If you have the schematic and care to share it with us, one of us would be able to help you out.
Audiofanatic
Be nice to animals.
Old 30th June 2003, 10:42 AM   #3
Cradle22's Avatar
Hi!
You can find it at ESP, but I steal a picture:
Just one comment: I do not use A1302 / C3281 but MJ15004 / MJ15003...
I had just an idea (but I am not home, so I can't check it), that it maybe R13 itself which could be faulty...
Bye,
Arndt
Old 30th June 2003, 11:25 AM   #4
Cradle22's Avatar
Hi!
Just got back, checked R13, and it was broken (infinite resistance).
Exchanged it, and now it works again...
Thanks anyway,
Arndty
Old 30th June 2003, 12:27 PM   #5
millwood is offline millwood  United States
Account Disabled
with the kind of voltage you got over it, it would have been generating hundreds to thousands of watts,
Old 30th June 2003, 06:06 PM   #6
kt88 is offline kt88
OP said infinite resistance - How does an open circuit resistor dissipate power ...
Old 1st July 2003, 06:41 PM   #7
EchoWars is offline EchoWars  United States
EchoWars's Avatar
It doesn't and he knows it. His suggestion was that the resistor must be open, otherwise with 38V across it, it would be dissappating over 3000 watts.
Old 1st July 2003, 08:44 PM   #8
Cradle22's Avatar
Would be a nice thing, simply disconnect the resistors, and 3000 W <output> power...
But those 2 * 100 W into 8 ohms from the P3A are sufficient for me...
Bye,
Arndt
Old 1st July 2003, 10:28 PM   #9
JOE DIRTŪ is offline JOE DIRTŪ  Canada
JOE DIRTŪ's Avatar
NO stealing pictures!!!!!!!!!!!!hahahahaha
Problems with P3A after refittingHide this!Advertise here!
ESP P3A problems cantabile Solid State 31 31st January 2007 10:36 AM
Sub Amp Problems Thanks! crippledchicken Solid State 2 10th January 2007 06:17 PM
Any problems with Fun-Tak (tm) on the PCB? fotzepolitic Solid State 10 1st February 2004 03:35 AM
BOZ problems - PLEASE HELP!! Tieftoener Pass Labs 10 5th December 2003 01:22 AM
Copyright ©1999-2017 diyAudio
