Just read the thread regarding the Passive preamp by HarryHaller, and got inspired. Passive Preamp
So I quickly drew up this schematic, anything wrong with it? I found a cheap alps 10k motorized pot ($4), so this is going to be real cheap... I think it's worth a try. What do you think?, suggestions? /Freddie |
#2 |
Connect the sources of the fets with a small value trim-pot to adjust for dc offset. The wiper is now your output.
Regards, Jam |
#3 |
Thanks for the suggestion Jam.
/Freddie |
#4 |
Suggestions for powersupply?
I'm thinking of using LM317/337 or perhaps 7824/7924. /Freddie |
#5 | |
Previously: Kuei Yang Wang
Location: Somewhere nice on planet earth where censorship of Ideas is frowned upon
Konnichiwa,
Sayonara |
#6 |
Banned
Could this schematic be used to drive a gain clone. ? I was thinking about maybe Building one for my small amps that i have completed..?
#7 |
You'll definitely need some source degeneration; the 50 ohm pot will help, but you'd do better putting a hundred or so ohms in each source lead, then select devices (or, gasp, servo) to minimize output offset.
The input resistor, R4, is much too small. At higher volume control settings, you'll be putting quite a load on the source components. And unless you have TOTAL confidence in the source components, I'd capacitively couple the input. That will make output DC nulling with an integrator easier, too.
If there's a sucker born every minute, where do the rest of them come from? |
#8 | |
Konnichiwa,
Sayonara |
#9 | |
#10 | |
My sources have no DC offset and my power amplifier is capacitor coupled, so I will not place a cap at the input. However thanks for the suggestions /Freddie |
| Buffered Passive I/V vs. Active I/V | VEC7OR | Analog Line Level | 3 | 23rd September 2007 12:38 AM |
| passive buffered line drive plans wanted! | shaun5 | Chip Amps | 0 | 11th December 2005 09:40 PM |
| Nuuk Buffered Passive Preamp Issue | filholder | Chip Amps | 51 | 22nd November 2005 09:00 PM |
| Struggling with my buffered GC preamp | Russ White | Chip Amps | 3 | 26th March 2005 08:12 AM |
| oscillation in passive buffered preamp | Flemming J P | Solid State | 13 | 22nd December 2003 04:42 PM |
