Old 4th August 2010, 06:30 AM   #1
jmillerdoc's Avatar
Default Minimum voltage for capacitor rails
Hello,
I am in the process of acquiring parts for an Aussieamps NX150 stereo amp. I have decided to go with 63v rails from a 45+45 600VA transformer. I was wondering if I could safely get by using 80v rated caps on the PSU or if I should go with 100v rated caps.
I would also like some suggestions for the best cap I could use here too. I have been looking at Cornell Dublier, Elna, Kendeil, and of course Nippon.
Jeff
Old 4th August 2010, 06:35 AM   #2
Mooly's Avatar
80 volt is fine, well within ratings even allowing for mains variations. Definitely no need for 100 volt rating.
Which caps... they are all good names. It's far far more important to ensure the wiring and layout is correct.
A good amp (high PSRR) correctly wired should be imune to it's PSU unlessthere is something grossly wrong.
A simulation free zone. Design it, build it, test it.
Old 4th August 2010, 06:49 AM   #3
ostripper's Avatar
I use 8- 80v nichicon 10,000uf caps . They were manufactured in 1992(datecode) , were used with 76VDC rails till 2002 in the original amp. Upon gutting the original , they were ESR tested with a "cap wizard" .. very low reading. I have now used the hell out of them in my new amp for 14 months .. absolutely no problem.
By actually testing these 18 year old Nichicons , I am amazed they tested so good only being derated by 4 volts. In fact I have 2009 4700uF caps that only test .1 ohm better on the ESR meter. VERY impressed with this quality.
If 80v units worked for 18 YEARS @76v , 63v would be nothing.
OS
Mongrel website , always current and updated :
http://67.248.209.21/D%3A/WEBSITE/
Old 4th August 2010, 08:34 AM   #4
Junm is offline Junm  Philippines
Junm's Avatar
Send a message via Yahoo to Junm
I also have this Nippon chemicon stuff and used for my amps and no problem at all. They are aged by still rugged.
Old 4th August 2010, 09:18 AM   #5
AndrewT is online now AndrewT  Scotland
do the arithmetic.
a 230:45+45 transformer running on a 240Vac that is at max 6% tolerance gives out 240*1.06/230 * 45 =49.77Vac
Now add on the transformer regulation to find the peak voltage before the rectifier.
Assume the regulation is 5%.
Output voltage is 1.05*49.77 =52.26Vac.
Peak voltage is sqrt(2) times Vac
Vpk = 1.414*52.26 = 73.9Vpk
The rectifier voltage drop at near zero current and with fully charged capacitors on minimum leakage current will be ~0.5V.
The worst case capacitor voltage is 73.4Vdc.
75 or 80V capacitors can safely be used.
I would advise reforming any old capacitors to their rated voltage before starting them on line.
regards Andrew T.
Old 4th August 2010, 12:33 PM   #6
jmillerdoc's Avatar
So even a 75v cap could be used then. Hmmmm, tempted to go with the 75v if the cost is even lower yet. Thanks for everyones help!
Jeff
Old 4th August 2010, 12:50 PM   #7
do the arithmetic for your supply voltage and for your transformer.
The numbers are different for each set of circumstances.
is it 110:45+45Vac, or 115:45+45Vac, or 120:45+45Vac?
is it 3.5% regulation or 4% or 4.5% or.....?
What is your nominal mains supply voltage?
What are the tolerances on mains supply voltage from your supplier?
If you do not know this information, play safe and use 250Vdc capacitors. Well that's as good a guess as any other.
regards Andrew T.
Zen V1 Higher Voltage Rails? fligti91 Pass Labs 4 13th November 2008 04:00 AM
Leach amp minimum rails Wynand Solid State 0 26th July 2005 06:10 AM
Minimum filament voltage for 300B kusojiji Tubes / Valves 32 6th July 2005 12:34 PM
measuring voltage rails Scribble Chip Amps 8 20th October 2004 12:03 AM
Imbalanced Voltage Rails on Gainclone Kofi Annan Solid State 2 2nd March 2004 03:13 PM
Page generated in 0.09953 seconds (78.51% PHP - 21.49% MySQL) with 11 queries
