Old 3rd August 2010, 02:33 PM   #1
Krisfr is offline Krisfr  United States
Wink Output PCB design thoughts
I am posting a sketch of a output section of a PCB design using Surface mount resistors for the emitter each of the resistors is one ohm so the sum is .5 ohm without the inductance of the wire wound inherit in type of this low ohmage and high wattage.
The circle is a cap of about 8 mm
Constructive comments are welcome. SMILE
Old 3rd August 2010, 09:05 PM   #2
nigelwright7557's Avatar
Loads of ground copper and powerplanes if possible.
It costs nothing to add copper just time.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 3rd August 2010, 09:51 PM   #3
Would it be sane to do this in a 4 layer board? with one layer solid Ground and another Solid Power split between the rails?
Old 3rd August 2010, 09:58 PM   #4
I usually get away with lots of copper on the power supplies and the output signal.
I wouldnt of thought it was worth the extra cost of going to 4 layers.
I do my best with two layers.
Old 4th August 2010, 10:26 AM   #5
AndrewT is online now AndrewT  Scotland
the big gap between the two rows of output devices demand a very tall heatsink. Gets big and bulky and heavy compared to a lower profile where all the devices are close spaced.
regards Andrew T.
Old 4th August 2010, 11:47 AM   #6
Take a pencil and divide the mounting space of the heat sink evenly according to the number of output devices.Find the center of each rectangle,that should be the ideal mounting place for each transistor.And don't get too worked up about resistor inductance,i am sure that its very low.
3-way hi-end design thoughts Mario Pankov Multi-Way 64 4th November 2010 08:42 PM
Leach 12 output pcb new Jens design. tryonziess Group Buys 2 21st February 2010 10:20 PM
Thoughts on my design? NogginBoink Subwoofers 6 24th July 2005 08:14 AM
LM4780 PCB Design Thoughts Gcollier Chip Amps 0 4th March 2004 05:51 PM
Thoughts on My Speaker Design Street Multi-Way 16 25th July 2003 07:29 AM
Page generated in 0.20689 seconds (35.30% PHP - 64.70% MySQL) with 11 queries
