#2571 | |
The paralleling issue for MOSFETs is indeed an interesting one, and much of what you say is true. I think the main reason I said that it was more difficult was because of the relative ineffectiveness of source degeneration in sharing current among MOSFETs that are not matched. The gate threshold voltages of randomly-selected MOSFETs can vary quite a bit, resulting in current hogging in the absence of source resistors. It is true that this is a smaller problem with laterals because they have lower gm and they also have the somewhat self-regulating characteristic in which conduction decreases as they get hotter over much of their operating current range; so one device that is hogging gets hotter and tends to back away from its hogging. This is not the case for verticals in the current ranges where we normally operate them (the TC crossover occurs at a much higher current in verticals). Nevertheless, even with laterals manufacturers generally must used matched sets of MOSFETs, be they vertical or lateral. It is desirable to use matched sets of BJTs as well, where they are matched for beta, but this is not as critical a matter for bias stability for BJTs when they are used with a reasonable value of emitter resistor. I'll try to give more attention to laterals in the next edition. I may even add a chapter or two on tube amplifiers. Many people were disappointed that I did not say anything about tubes, but instead went to the "dark side" in covering class D amplifiers :-). Cheers, Bob |
#2572 |
Now we know why so many MOSFET amps only have one pair of output devices . . .
#2573 |
I have a few comments/questions about this topology.
This is a fully differential amplifier. To accomplish this two equal loads are placed in the two collectors of the input differential amplifier, the ouput beeing take differentially. To have enough gain, these two loads should have very high resistance. In IC design this is done by putting two identical current sources one in each collector. But now we have a biasing problem the current source of the differentail amplifier and the two loading currents sources are both establishing the bias which is not possible. The trick is to create a signal equal to the common mode and to feed it back to control one of the bias source, in this way there is only one bias controling element. One simple way to do this is to use two identical resistors as in the fig attached. The mid point of the two resistors cancels the differential signal and is proportional to the common mode voltage. This is applied to the bias voltage of the two current sources. But now we have a voltage gain equal to gm ro R where ro is the output impedance of the loading current sources, the resistor should again be high. In IC technology the resistors are limited. A way to increase them is to insert an emitter follower before each resistors and this is the topology found in the book. The question I have is : In discrete design we can use very high value resistors. Should we not have essentially the same performance by simply putting two equal and high resistors either as in the figure or simply in each collector. JPV |
#2574 |
Found three copies at a Half Price Books in brand new condition.
I've previously lost two to possibly permanent loan-outs, So I picked up a few spares. Wonder how long these will last me? Isn't it a little too soon for this book to be found at discount? Nineteen bucks I gave, couldn't believe it. Half? Not even half... I didn't hesitate to quibble over which edition. Last edited by kenpeter; 7th February 2013 at 01:23 PM. |
#2575 |
The gain should read: gm ro2//r04//R
R is limiting the gain |
#2576 |
Hi Bob,
What's the prefered sensing location of a VBE device, for vertical mosfets (k1530 & j201 pair), if they are matched for 5% Vgs in a typical high power application, perhaps with a +/- 75v supply...? On top of the device or heatsink...? I 've read that mounting the Vbe on heat sink would suffice in chapter 11 (fig 11.8) of your book. Does mounting the device on top of the output devices would over compensate....? |
#2577 |
The preferred sensing locations are the voltage drops across the source series resistors.
![]() Cheers, E.
Een volk dat voor tirannen zwicht, zal meer dan lijf en goed verliezen dan dooft het licht…(H.M. van Randwijk) |
#2578 | |
Best wishes David Last edited by Dave Zan; 7th February 2013 at 09:43 PM. |
#2579 | |
Class-D is the future. More on Class-D! More on advanced high-order loops and how to make them stable under clipping conditions. Basically tell us all about NCore
#2580 | |
"I may even add a chapter or two on tube amplifiers". Don't. Hollow state will require more than a "couple of chapters" to do it right. Many of the concepts carry over from SS to HS, but the design details are very different. Besides, Morgan Jones has this covered. Maybe more about Class D, for those who're interested? "Class-D is the future". Not really, it's been around for quite a few dog's ages now. You can also implement Class D in hollow state, as it was first done back in the early '50s. |
| best audio amplifier book?? | Bouvett | Everything Else | 30 | 13th August 2012 02:43 AM |
| Another realization of Bob Cordell's THD Analyzer | giulianodes | Equipment & Tools | 12 | 3rd August 2010 01:57 PM |
| Amplifier Design Book | pixie | Everything Else | 27 | 11th June 2010 08:36 PM |
| Project 11.1 from Slone "High-Power Amplifier" Book | Karl71 | Solid State | 46 | 6th October 2008 03:47 AM |
| book-audio power amplifier by Douglas Self | mikee12345 | Solid State | 8 | 16th November 2003 01:16 AM |
