#2531 | |
As is often the case for me, I'm not 100% sure I am visualizing the intended circuit or implementation, specifically the above mentioned RC shunt compensation. Since this is Bob's thread would it be possible to reference a specific figure(s) in his book? I would think that Bob would encourage and benefit from such a discussion. Keantoken, your electronics insight is amazing for someone any age, but at your age its truly a gift. Thanks -Antonio |
#2532 |
Hi Guys
In Bob's book, see figures 4-11/12 7-15, 7-16 (front-end of his mosfet amp) 9-4/5 for TPC, BTC compared to miller 9-6 for input comp 9-7 for MIC 9-8 for "inclusive miller" wrapping output stage and VAS 9-9 for TMC 25-15 for a non-global-FB amp with similar front-end to 7-16 Also look at Self's notes about VAS gain reduction using an R in parallel with the miller cap. In his 5th-ed PA book, fig.5-16b and 5-17 graph. The latter shows low-freq gain reduction without altering high-freq performance. Have fun Kevin O'Connor |
#2533 | ||||||||||
Magnoman, where is it you read about my age? It was probably a very old post. I'm older now.
![]() Quote:
The Kmultiplier rail filter! LTSpice wiki with special attention to new users' troubles Last edited by keantoken; 13th December 2012 at 04:45 PM. |
#2534 | |
Indeed it was an old post (dont remember where) but you were 17 then !!! Sorry but I dont understand your reference to RC shunt across the TIS input, basically the loss of pole splitting? For more complex high order compensation, I know its not a problem in the audio spectrum but, should we at least verfy that the effects on settling truly can be ignored (and it might be fun and instructive), similarly with unconditional stability. Thanks -Antonio |
#2535 |
So 17-2006+2012 = 23 years? (still pretty young, btw, I'm almost 70
Een volk dat voor tirannen zwicht, zal meer dan lijf en goed verliezen dan dooft het licht…(H.M. van Randwijk) |
#2536 |
I'm 19 now, I think. So I guess not that long ago.
RC shuntcomp is improved by significant TIS degeneration, and in this case degeneration doesn't decrease VAS gain at audio. Otherwise, varying VAS Gm will cause wandering poles... I'm not quite sure what you mean by settling. If you mean energy stored in the RC time constant, then this can be problematic if the frontend is repeatedly saturated, but recovery is usually more than fast enough. For fast amps the RC time constant can be quite small. I don't get unconditional stability so much. An unconditionally stable amp can still ring like crazy and oscillate into an output cap, based on the "unconditionally stable" amps I've seen. I don't have much faith in unconditional stability. |
#2537 |
#2538 |
Keantoken
Maybe you can post a sketch I suspect I'm not understanding your circuit. How is it that adding degeneration doesn't decrease gain under 20Khz, unless the next stage has a very high input impedance, and doesn't miller compensation move the stages next pole further away. By settling with higher order compensation I meant the effects you will see from having multiple rc times, essentially going from hf to lf, which would be evident in step responses (again at very low level, still fast and likely not an audio problem but worth seeing). I should have said conditional stability, as with higher order compensation there is more chance of having 180 phase shift within the loop cross-over frequency, and the potential for having a gain reduction initiate oscillation such as during start up or approaching clipping. 19, geez, still in college thats a little depressing, Are you near SanAntonio, if so you should look at working summers at SwRI. Thanks -Antonio |
#2540 |
Closer to Dallas actually. BTW, feel free to talk to me if there's something I can do for money.
I think you mean gain margin. I have to admit I don't find myself needing OLG graphs much. I can look at differential output current and output impedance and that tells me most of what I need to know. Whenever I've checked gain margin with OLG it was good enough. There is some overshoot with this type of compensation. Overshoot increases with a smaller capacitor, and you don't necessarily need the smaller capacitor for lower audio distortion. In my latest schematic I increased the cap from 560pF to 10nF, reducing overshoot to 1% and THD changed only by about 4db. I was surprised. So it seems this circuit's limitation at the moment is not the compensation. Here are AC response, OLG and FFT plots from a "generic-kean" amp I threw together in the simulator. FFT is taken at 33V into 6R (90W). The circuit is a generic Blameless with 3 tricks, one of which is the shunt compensation. It seems my compensation techniques confuse the OLG probe, so there is a phase offset. I built my last amp which used this compensation scheme and aforementioned tricks, so I know it works. The red trace is with compensation set to 2.5% overshoot, the orange trace is for 20% overshoot. |
| best audio amplifier book?? | Bouvett | Everything Else | 30 | 13th August 2012 02:43 AM |
| Another realization of Bob Cordell's THD Analyzer | giulianodes | Equipment & Tools | 12 | 3rd August 2010 01:57 PM |
| Amplifier Design Book | pixie | Everything Else | 27 | 11th June 2010 08:36 PM |
| Project 11.1 from Slone "High-Power Amplifier" Book | Karl71 | Solid State | 46 | 6th October 2008 03:47 AM |
| book-audio power amplifier by Douglas Self | mikee12345 | Solid State | 8 | 16th November 2003 01:16 AM |
