#2401 | |
This seems like a neat idea. I agree that a little bit of overcompensation is OK. Nice pic! Cheers, Bob |
#2402 |
Hi Bob,
Well I've been having a great time playing with LTSpice, all thanks to your book, and I wondered... generally speaking, how well do you find circuits simulated with LTspice translate into real life circuits ? I can see how easy it is to chase the minute details... for example changing a transistor type to eek that extra 0.0001% of something or other when perhaps realistically that all falls apart a little in a real build. That was one question I have wondered over for a while, but I have encountered a bit of a puzzle with a simulation that makes me wonder all the more. (and I know the real answer is to go and build the thing ) So I have a design in simulation that gives spectacularly bad results on slew rate (50Khz squarewave test) when using the MJE340C model as a VAS. It's that slow you would need to send it a postcard with advance warning a voltage change was coming. However if I swap it for pretty much anything else the results are more in line with what I might have expected. The VAS current is highish by design at around 25ma. If I modify the drive to the VAS as shown in red then it works OK although at the expense of other aspects of the design suffering. What parameter/s of the transistor model might be causing this slew limiting effect ? and do you think this a real effect if it were built for real using an MJE340. Your 2SC3503C model on the other hand gives a very good result in simulation.
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#2403 |
Mooly have a look at CJE and CJC. Its real.
Here is a useful program that all could use to verify their spice models with datasheets. Wolfram Demonstrations Project |
#2404 |
It appears the base feed into the 340 does not like the 3k9 as source resistance.
Changing that to 330r sorts the RC slew limiter. But, why run the preceding EF with an Ie~0.15mA. simply reducing the 3k9 emitter resistor to somewhere between 99r and 1001r would be more sensible. |
#2405 |
Thanks homemodder, that's spot on.
I just tried adding a little junction capacitance to the 2SC3503 and that's it. Couldn't see it for looking Thanks for the link too.
#2406 | |
Sheesh, and when I think of all the 1000's of line driver and PSU faults I have worked on where slow turn off has been the trouble. Inexcusable
#2407 | |
I'm sorry I did not get back to you sooner. It looks like you have already gotten some good answers. When I saw your post I looked at my MJE340C model, thinking it might have something wrong with it. The CJC is particularly high for this part; so high that I went looking at the datasheets for it and commercial SPICE models for it. Most of the datasheets for this device are among the most awful I have ever seen. I did, however, convince myself that the CJC is fairy real and that my Tf, reflective of ft is about right. For my model, at 10V and 10mA, Cbc = 59 pF and ft = 19 MHz. I was still surprized at how different the results were that you got between it and some other transistors. This all underlines how important SPICE simulation is and how important reasonably accurate transistor models are. Two of the biggest reasons I use SPICE are: 1) I want to avoid surprizes when I build the circuit; 2) I want to be able to quickly play with different circuit architectures and component values. I often find a fundamentally better circuit architecture or better set of component values after only a few simulations. I find the insight to be incredibly valuable. I especially never want surprizes with the DC values. I have also found SPICE to be quite reliable in predicting instabilities that are not a result of real-world implementation parastics that may not be modeled. If a circuit shows signs of peaking or instability in SPICE, you are very likely to have trouble in the build. With respect to distortion, SPICE gives useful information (again, limited by the accuracy of the transistor models) in a relative sense, but if I come within a factor of two of real-world measured distortion I feel good. I don't set my expectations high for distortion correlation, but I do find SPICE valuable in evaluating topologies for distortion creation. Class A small-signal distortion that depends largely on the exponential Vbe characteristic comes in pretty well. That which depends on beta nonlinearity also comes in fairly well if the transistor models do a decent job of modeling beta. Distortion dependent on Early effect comes in less well, and the way SPICE models Early effect is not that great - and VAF parameters in models are often all over the place. Distortion in class AB output stages resulting from static or dynamic crossover distortion is less dependable. Power MOSFETs generally need to have decent EKV modles (rare) for good modeling of class AB output stage distortion. My philosophy is that the IPS/VAS can and should be good enough to the point that the output stage distortion is what is left dominating the overall distortion of the amplifier. I hope this helps. Cheers, Bob |
#2408 | |
All the trouble I've ever been in started out as fun......
#2409 |
Thanks for the detailed reply Bob,
I'm quite a long way off creating models or altering models at the moment, it's all very much an (enjoyable) learning adventure at present. I'm beginning to see that decent models are absolutely vital to achieving realistic results and distortion modelling is one aspect that is really beginning to intrigue me with Spice. I found trying something a bit unlikely such as using a medium power device (2SC3503) as an input stage can throw up surprising results. Heck I even tried lateral and hexfets for the input... and it wasn't all bad, that's for sure. In fact I'm amazed at some of the figures I'm seeing in general, sub 0.00015% THD. All intriguing stuff. Next up for me is to try and copy your "A weighted filter" from your examples and insert and include that into my simulations. Thanks again, and the book is proving invaluable help for all this. I'm sure without it I'd still be staring at a "new schematic" screen and wondering where to begin.
#2410 |
Mooly, figures like that with your circuit at 1 Khz is quite possible but what you should also look at is at how other parameters affect the design as well. For instance VAF which is early voltage is also very important. You could find a part say with very low capacitances but low early voltage, this would cause low high frequency distortion (20khz) but much higher distortion at 1 khz and lower frequencies. Rule of thumb, capacitances effect mostly high frequency operation while early effect the low frequencies, this is very important especially when there are large voltage swings present ie vas. For instance using a 2n5551 as vas in your circuit should show lower distortion at 20khz then 2sa3503 but because of the laters much higher early voltage it will outperform the first when low frequencies come into play. If this doesnt show in the simulation the models are defective. In your case you were wise to look at the square wave responses as the mje340 could show lowish distortion at lower frequencies due to its highish early voltage but perform terribly at high frequencies ie the mje will for instance outperform a bd140 at low frequency but at 20khz the bd will be superior. The point in frequency where this interaction takes place is not always clear so one needs to check THD at low and high frequencies. This interactions also effects the harmonic structure but instead of a short explanation Ill refer to a paper below where real life examples are shown and you can deduce from there. Harmonic structures can be manipulated to a certain degree if this is your type of thing with just the choice of component used.
This is a subject that should appear in audio amplifier books although it hasnt yet but samuel groner has shown and discussed these effects in his paper shown here on DIYaudio. Its very informative and a must read on this subject and some others. |
| best audio amplifier book?? | Bouvett | Everything Else | 30 | 13th August 2012 02:43 AM |
| Another realization of Bob Cordell's THD Analyzer | giulianodes | Equipment & Tools | 12 | 3rd August 2010 01:57 PM |
| Amplifier Design Book | pixie | Everything Else | 27 | 11th June 2010 08:36 PM |
| Project 11.1 from Slone "High-Power Amplifier" Book | Karl71 | Solid State | 46 | 6th October 2008 03:47 AM |
| book-audio power amplifier by Douglas Self | mikee12345 | Solid State | 8 | 16th November 2003 01:16 AM |
