#1971 | |
Pioneer M7 Exclusive Service Manual free download,schematics,datasheets,eeprom bins,pcb,repair info for test equipment and electronics
regards, Pawel |
#1972 |
Banned
padamiecki,
certainly, distortions including memory distortion are reduced, but that is not a specific, exclusive way to address memory distortion. Memory distortion is just a part of a complex distortion pattern. |
#1973 | |
if you was looking for sophisticated discussion about memdist - what a pitty - all I know is that a single ss device (a transistor) can remember for some time the current that came through it and in that way caused distortions. A complex of the devices which are working at constant current or voltage is better, but the best is when constant power through them is assured, which is similar like for electron tube, which sounds for me the best. There are many things to consider to get good amp, but for me cfp input + cascoded vas = beware, the sound might be good.
regards, Pawel Last edited by padamiecki; 21st June 2011 at 12:29 PM. Reason: gramma |
#1974 | |
Thanks for this heads-up. Pioneer did indeed make some good stuff. Cheers, Bob |
#1975 |
Banned
padamiecki,
constant power implies constant DC bias current and voltage (it cannot be more constant: P = I * V), which is mandatory for linear transformation, but can be provided by other means than cascode and CFP. |
#1976 | |
I have not used a Baxandall super pair as shown in the link you provided, but I have largely used it in an emitter-follower kind of configuration, which, when done in a complementary way, becomes somewhat of a diamond buffer where the collectors of the first pair are bootstrapped to the output node instead of connected to the rails. I used such an arrangement in the amplifiers I designed for my Arthena active loudspeaker systems, where I used BJT folded emitter followers to drive output MOSFETs (described on my web site at CordellAudio.com - Home). The collectors of the folded emitter followers were connected to the output node. That is also when I used the Flying Catch Diodes for the first time. I haven't seen Andy's work on the CFP stability yet. Cheers, Bob |
#1977 | |
These are great suggestions for better coverage when I do the second edition of my book. I encourage everyone to bring these sorts of things to my attention. It is much appreciated. Cheers, Bob |
#1978 | |
, but look to the Japanese OEM's for some of the best topologies. The OEM's are not dumb (economically driven sometimes) in their design choices. For high MTBF and cheap STK module offerings they use the standard 3-stage LIN topology with varying degrees of refinement. For a real "listening amp" (mid to audiophile) Push -pull VAS's and triple OP's are the rule. The pioneer amps are quite revered in their MTBF and sound. Thank you , padamiecki .. for the M7 schema. It looks different than the "DBT", more like the voltage follower DB current amp (my nakamitchi 620 example). This means that Bob's "DBT" is unique to the book , no exact commercial equivalent. More "DIY" friendly as well , it can be used with any popular IPS/VAS combo plus is quite easy to thermally stabilize. I would say it's ultimate form would be with the Thermaltrack's , 2 of the internal diodes controlling the Vbe (like the leach). Njl3281/1302 is out of the reach of some hobbyist's ... 5.41 X 12 = $65usd for a 2 X 150W amps. Same power with the NJW's is only 1.80 X 12 = $21usd for the same 150W ! OS
Mongrel website , always current and updated : http://www.fidelityforce.com/ostripper |
#1979 |
Mr Baker also changed his mind a couple of times
![]() (fun about the P-Exclusive series is the design evolution across the successive models. Even the early '70s models had glass fibre epoxy boards with 4Oz copper, HQ items)
Not so much,.......if it says "ZM" in the corner. |
#1980 | |
| best audio amplifier book?? | Bouvett | Everything Else | 30 | 13th August 2012 02:43 AM |
| Another realization of Bob Cordell's THD Analyzer | giulianodes | Equipment & Tools | 12 | 3rd August 2010 01:57 PM |
| Amplifier Design Book | pixie | Everything Else | 27 | 11th June 2010 08:36 PM |
| Project 11.1 from Slone "High-Power Amplifier" Book | Karl71 | Solid State | 46 | 6th October 2008 03:47 AM |
| book-audio power amplifier by Douglas Self | mikee12345 | Solid State | 8 | 16th November 2003 01:16 AM |
