Old 15th April 2011, 09:28 AM   #1611
xsmid4 is offline xsmid4  Czech Republic
you think THD below 0.001% in whole audio range is not possible? look at this:
CustomWorks Zesilova? – HYPA A400
Old 15th April 2011, 10:16 AM   #1612
Those PCBs and layout style look very similar to those developed by one of our Membership.
Do you know the "name" behind SPaudio?
Old 15th April 2011, 10:30 AM   #1613
yes, SPaudio and Customworks is the same "brand", the amplifier is developed by hcrevize and Page.P members
Old 15th April 2011, 10:34 AM   #1614
the PCB layout is very similar to Pavel Dudek designs, but the circuit is different
Old 15th April 2011, 12:38 PM   #1615
wahab is offline wahab  Algeria
frankly, i don t believe that 1000 ppm is , honestly, audible,
so the whole debate of ppm range distorsion is more or less
a useless one , and there s other important areas,as stability,
wich are generaly neglected as an inherent trade off to
achieve low levels of distorsion....
Old 15th April 2011, 05:07 PM   #1616
Default amp distortions
I think you are wrong.
0.1% of crossover distortion is very likely to be audible.
Old 15th April 2011, 05:57 PM   #1617
Originally Posted by Macleod View Post
Hello Bob,
The world is small as I wanted to ask today the same question as Roland. You gave me some answer right now by providing the simulation files. I will investigate more with them following days.
Thank you for this.
Moreover, I would like to ask you something I can't find in your book up to now.
Fig9.7 gives the basics of the compensation used for your design. MIC (Miller Input Compensation) is used and several R-C networks added on the high impedance points. Your Mosfet Amplifier Fig11.17 also has TMC (Transitionnal Miller Compensation). Your Mosefet Amplifier Fig25.15 also has MIC.
My question is : What is your methodologie to make all that work stable with good phase and gain margin? There are 7-8 components to tune, we are far from the simple Miller compensation used in more common amplifiers.
Do you probe the various loops (which one?) and adjust phase and gain margin for each one? How do you balance the value for each R-C couple? Do you step all components up to a good result? How do you define the work is finished?
I would be interested if you could share the way you work before providing the final results.
If other talented designers could also share the way they would adjust such a design, I would appreciate it very much!
Thank you all for your comments!
Laurent
Hi Laurent,
I first started using Miller Input Compensation in my MOSFET power amplifier with error correction published in the JAES in 1983. In that design I had the Miller compensation capacitor go from the VAS hi-Z node back to the input diff pair (i think there was also a small resistor in series to provide a zero in the compensated response). The value of that "Miller" capacitor is set to establish the desired gain crossover frequency of the amplifier. Its reactance should equal the resistance of the feedback resistor at the gain crossover frequency. That part is pretty straightforward. The rest of the compensation is there to stabilize the semi-local feedback loop formed by the Miller feedback. This loop does not involve slow power transistors and is not strongly affected by amplifier output loading, so its gain crossover frequency can be larger, on the order of 10 MHz. In that 1983 amplifier design, I placed a series R-C network across the outputs of the input differential pair to stabilze the compensation loop.
The resistance and capacitance of that added network were tweaked to provide good stability margin as seen by squarewave probing at various points in the circuit (I was not using SPICE simulation for power amplifier design back then). There was not a lot of explicit design calculation in setting those values, but they were chosen to yield a gain crossover frequency for the compensation loop in the neighborhood of 10 MHz as a starting point. A starting point for the resistor was to create a zero at about an octave above that loop's gain crossover frequency.
In later designs using that same IPS/VAS/MIC topology, I discovered that in some cases it was desirable to add a series R-C network shunting the VAS output node to ground. In designs with low capacitance at that node, the majority of signal current could flow through the Miller compensation capacitor back to the input stage input node. The inclusion of the added R-C network diverts a good fraction of that current from flowing that way, better defining the loop gain of the Miller compensation loop. The capacitance of that added network is chosen small enough so that it does not seriously impair the slew rate capability of the VAS. That network also helps significantly in situations where the Miller feedback is taken from the emitter of the pre-driver rather than directly from the VAS hi-Z load. Its presence serves to better define the VAS voltage gain at high frequencies and provides an opportunity to add a zero.
The values of these components were all tweaked by trial and error while looking at circuit stability with simulations. I wish I could say that I came up with an algorithm or converging design procedure to arrive at the values, but I didn't.
Stability of the compensation loop was evaluated by looking at numerous nodes with frequency response and square-wave excitation. The most significant tool was looking at the frequency response of the feedback signal on the input of the input differential pair when the global feedback was made about 100 times smaller. Ideally, this node should have unity gain from the amplifier input (it is a voltage follower). There should be no peaking evident at this node. One will see rolloff beginning in the neighborhood of 10 MHz, which is the closed loop frequency response of the compensation loop.
Bob
Old 15th April 2011, 06:04 PM   #1618
Originally Posted by PHEONIX View Post
Hello Bob
Thankyou very much for your response. In my experience I think that its not trivial to get THD-20 =0.001% at 44V peak into 8R (200K BW) and going to 0.0001%(1ppm) is very hard in real hardware. Curiously the simulator is OK at predicting say the Blamless circuit performance but begins to get very optimistic at the 0.0001% levels I think that to get real circuit performance at these levels your simulated THD needs to be much lower.
Arthur
I agree with you that getting THD-20 (NOT just THD-1) down below 0.001% is difficult in a real-world circuit. However, getting simulated THD-20 further down will not necessarily be sufficient to get there, since the distortion floor might be set by implementation imperfections that have nothing to do with the simulation.
Bob
Old 15th April 2011, 10:53 PM   #1619
You are wrong, since you cancel the fact that i was
responding to a post that stipulated THD...
You bring things out of context to make discutable points,
but still a wrong one, since 0.1% of distorsion, be it crossover one,
is hardly audible...
Old 15th April 2011, 11:45 PM   #1620
Hi wahab,
Although correlation between THD and sound quality is sometimes much less than we'd like, I would not throw the baby out with the bathwater. 1000ppm is a lot of distortion for a solid-state amplifier, and it is likely that such an amplifier will not sound great. However, it is true that softer forms of distortion at such levels, such as in a vacuum tube amplifier or from a soft clipping circuit, will often not sound objectionalble.
A solid state amplifier that has 1000ppm distortion from the usual solid state distortion sources is probably not well designed and will probably sound bad. Some forms of distortion, such as crossover distortion, which shows up as THD, can be quite objectionalble even at lower levels.
Bob
best audio amplifier book?? Bouvett Everything Else 30 13th August 2012 02:43 AM
Another realization of Bob Cordell's THD Analyzer giulianodes Equipment & Tools 12 3rd August 2010 01:57 PM
Amplifier Design Book pixie Everything Else 27 11th June 2010 08:36 PM
Project 11.1 from Slone "High-Power Amplifier" Book Karl71 Solid State 46 6th October 2008 03:47 AM
book-audio power amplifier by Douglas Self mikee12345 Solid State 8 16th November 2003 01:16 AM
Copyright ©1999-2013 diyAudio
