Bob Cordell's Power amplifier book
Old 4th March 2011, 01:55 PM   #1541
Macleod is offline Macleod  France
Originally Posted by Olivier73 View Post
Off-course, anyone is free to comment on the clamps, but on the whole circuit too !!!
For now simulation shows 1.6ppm THD20 at full swing - not loaded (only vas & ips, no ops!).
Quite complex. No?
Is that complexity to have low distorsion at 20kHz? But your figure is without OPS. So...
Old 4th March 2011, 09:38 PM   #1542
Olivier73 is offline Olivier73  Belgium
Default thd
Hi Macload,
I am aware of the relativity of THD figures, especially if it is w/o OPS. Maybe a bit surprisingly, I am not specificaly searching for THD world records, far from it. So why the the complexity? Well because I like the Mirror Image topologies with current mirror loaded LTP's combined with a Cascoded darlington VAS. Off-course there is the VAS Iq issue, and I see it as a challenge to solve it (even if I have not invented the solution for it - my capacities are too limited for that). As a matter of fact I started out with this circuit reading Randy Slone's book. I lost much time with, but I learned a lot of things while burning down too many transistors... So I have a strong will to make it work...
My concern for the moment are thos clamp diodes in the VAS and in the IPS. I have seen so many different options ... is this a good one?
Cheers
Olivier
Old 5th March 2011, 12:42 PM   #1543
Bob Cordell is offline Bob Cordell  United States
Originally Posted by dadod View Post
Hi Bob,
Thank you for your comments.
I wanted to keep drain - source valtage constant. Luxman amp did it simple with resistor devider. Roender is using something similar in his one stage amp.
I don't understand what you mean by using emitter follower. How to connect it to feedback signal? If you could put some diagram here, as I did not find, how to best bias a cascode, in your book.
C7 is suggested by Samuel Groner in his comment on D.Self. It enhace slew rate. And indeed in my simulation it increased dow slope from cca 70V/us to cca 90V/us. Comments on Audio Power Amplifier Design Handbook by Douglas Self
R42 is used to adjust the bias. I used your suggestion for ThermalTrak from the tread Biasing/thermal compensation of Thermal Trak transistors
I included a new LTSpice with simpler cascode bias, TTP tail current of 6mA.
Damir
Hi Damir,
I guess the use of C7 is a way of getting the VAS to act in a push-pull sort of way at HF without going to the trouble of a complementary VAS and complementary VAS drive arrangement. It may increase the slew rate, but I just would not go there. Whether it increases slew rate depends on where the slew rate limitation in the amplifier without C7 is occurring.
The emitter follower I was mentioning would have its base connected to the tail of the LTP and its emitter would be used to drive the common mode signal to the bases of the cascode. This buffers the tail from having to be loaded and to have the extra bias current injected.
Bob'
Old 5th March 2011, 01:52 PM   #1544
dadod is online now dadod  Croatia
dadod's Avatar
Originally Posted by Bob Cordell View Post
Hi Damir,
Bob'
Hi Bob,
I hope I understand how to do that. Something like this?
regards Damir
Old 7th March 2011, 11:06 AM   #1545
Hi Bob,
Reading about Bakerclamps in your book I implemented some in the joined circuit. Are these well placed?
For information : OPS is still not implemented nor is the bias circuit.
Olivier
Hi Olivier,
You've got a lot going on in this circuit. It looks like you are using clamp diodes that effectively feed back from the output of the VAS to the input of the VAS to keep the VAS out of saturation. This is not the usual use of Baker clamps in a power amplifier. The usual approach is much simpler, and was used, for example, in Tom Holman's APT-1. The clamp diodes go from the output of the VAS to a fixed voltage reference, preventing the VAS output from going more than a diode drop beyond the reference. The arrangement assumes a current-limited VAS.
Bob
Old 7th March 2011, 11:08 AM   #1546
Hi Bob,
regards Damir
Hi Damir,
Yes, but you may want to replace R26 with a zener diode. As shown, it looks like there will be attenuation of the common-mode signal before it reaches the bases of the cascodes.
Bob
Old 7th March 2011, 08:28 PM   #1547
kenpeter is offline kenpeter  United States
Bought my copy today at lunch. Nerdbooks.com in Richardson, TX.
Weird place, four large dogs follow you around. Then you have to
buy online from a Mac terminal, won't take cash. But also did not
have to pay shipping...
Also bought a book by Douglas Self right next to Cordell's. Couldn't
find Morgan Jones Valve Amplifiers. But they said they could get it.
Old 7th March 2011, 09:39 PM   #1548
Hi kenpeter,
Thanks for buying my book and I hope you enjoy it.
I recently bought Valve Amplifiers by Morgan Jones from Amazon and I have given the whole thing a first pass look. I really think it is a good book.
Bob
Old 8th March 2011, 02:43 AM   #1549
The two things that drew me to the book were EKV models and KK.
But there is wayy more other good stuff here than I was expecting.
I am trying to understand how to hybrid model the IRFP240/9240?
Gather would have to be a .subckt, [CTRL+RightClick] and change
prefix field from MN or MP to X. Would you be OK with discussing
specific book given models outside the book?
Old 8th March 2011, 06:47 PM   #1550
Hi kenpeter,
Yes, I would be happy to discuss models, but I have to be careful what I promise because models can be a real time sink.
I'm still trying to finish up the new group of model updates I will be posting on my website. Almost every time I look at modeling I get angry with the manufacturers because their models are so awful. Look at the MJE340/350 spec sheet - they don't even quote ft, much less provide a graph of it.
Bob
Bob Cordell's Power amplifier bookHide this!Advertise here!
Project 11.1 from Slone "High-Power Amplifier" Book Karl71 Solid State 47 12th April 2018 02:47 AM
book-audio power amplifier by Douglas Self mikee12345 Solid State 12 6th January 2018 09:57 AM
Another realization of Bob Cordell's THD Analyzer giulianodes Equipment & Tools 136 6th June 2016 08:06 AM
best audio amplifier book?? Bouvett Everything Else 30 13th August 2012 02:43 AM
Amplifier Design Book pixie Everything Else 27 11th June 2010 08:36 PM
