#1341 | |
Thanks JPV |
#1342 |
because you missed the doubling of the diff pair gain by the mirror?
2*(1/(2*(470 Ohm + 26 mv/0.5 ma))) ~= 1/500 mho with ~15 pF Cdom ~= 20 MHz GBW then with the beta of 1/20 pretty much gives the observed 1 MHz corner freq for more fun with my delay sim you can edit both circuits to TMC and measure the outer loop gain in one and inner loop gain in the other the final 100 ns delay step @5 gives very close to the same `1.7 MHz intercept and -2 to -4 degrees phase margin - so you could say measuring the outer loop gets you the same stability result if you add delay externally - it just doesn't help you predict the stability limit from the 0 delay plot a good question is why the resistance to measuring the inner loop? Probably because we expect just measuring the outer loop to be right from experience with 1st order loops as in the CMC case there are complex rules for measuring multiloop circuit stability by "loop cutting" methods - the simplest is that measuring the global outer loop gain/phase margin is sufficient if all internal loops are negative feedback and are stable - I think the "fail" is that TMC is a positive feedback loop - admittedly expected to be stable if the output stage gain is less than unity I think the probe position in my sims is adequate because it breaks both the global and local output stage feedback at the same time and the remaining “inner” miller feedback around the VAS is negative feedback and stable to anticipate a possible objection - the delay element could be put in-between the driver and output Q with little effect on the result if you just like the visual appearance of not modifying feedback component connections the delay following the output Q and RL is probably a little better since the pre/driver see the output Q's base load - I don't know how to make a "reciprocal" delay Last edited by jcx; 4th January 2011 at 11:58 PM. |
#1343 | |
The amount of bridging capacitance needed to suppress the loop gain peaking will of course be highly dependent on the particular design. 0.2pF was not enough to do it in my design. Other designs, which use higher overall values of compensation capacitance will need even more bridging capacitance. Of course, a design that does not use an emitter follower in front of the VAS transistor will typically not need the bridging capacitor because that function will be performed by the collector-base capacitance. But I don't think we are talking about such low-performance designs here. I would not leave the bridging capacitance to chance. In fact, I think a decent layout would not have anywhere near 0.5 pF (or even 0.2 pF) from the VAS collector to the input of the emitter follower feeding the VAS transistor. On the other hand, one could do the calculations and deliberately create some PWB inter-trace capacitance to fulfill the role of C3. Could you clarify your statement: "As i already pointed, a TMC network pondered with a TPC one is generaly the optimmum in respect of the global behaviour, although i m not still sure if there isnt undesirable by products." Cheers, Bob |
#1344 | |
My understanding and sims do not indicate the the inner loop around the output stage is a positive feedback loop. This is the loop that starts at the output of the amplifier, passes through R1, and gets to the input of the VAS through C1. Although C2 is connected to the input of the output stage and to the output of the VAS, it provides less transmission to the output stage than the path through C1. If you open the global loop, and also open the local loop at R1, then apply a signal to R1, you will see the loop gain of the local loop. You are certainly correct that just looking at the global loop is insufficient. The total amount of feedback enclosing the output stage derives from two paths, one the global feedback path and the other the local loop path. The sum of the loop signals of both of these paths is what causes the output stage to be enclosed by the feedback that has the peak and typically has a higher gain crossover frequency. Cheers, Bob |
#1345 | |
#1346 |
Hi Stinius,
This is certainly true, but it is only my opinion that before one applies TPC or TMC to get really high performance out of a design, they should have at least given the design a decent VAS (with an emitter follower in front of it, what we often call a Darlington VAS). Just my opinion on priorities, and others may of course differ. Cheers, Bob |
#1347 | |||
Hi jcx, I'm not sure if you consider me part that 'engineering oriented community', but years ago I already said that any compensation trick (and even HEC) that lowers the distortion, has an impact on the stability. So I fully endorse the TANSTAAFL principle. Quote:
![]() (just teasing a bit) Quote:
However, your stability test, using a simple delay, provides less ambiguous results, as it doesn't rely on inductances, which may vary from amp to amp. IOW, it's more 'robust'. Cheers, E.
Een volk dat voor tirannen zwicht, zal meer dan lijf en goed verliezen dan dooft het licht…(H.M. van Randwijk) |
#1348 | |
I read on your shematic a resistor of 3000 instead of 2000 which gives a beta of 16 instead of 20, therefore my mistake Thanks for the answer. |
#1349 |
Banned
Edmond,
you mean you give distortion and get linearity and stability in your 1st order system? Sounds like a good deal. |
#1350 |
Oh boy! The beginnings of a new obtuse discussion....or is it the same one?
| best audio amplifier book?? | Bouvett | Everything Else | 30 | 13th August 2012 02:43 AM |
| Another realization of Bob Cordell's THD Analyzer | giulianodes | Equipment & Tools | 12 | 3rd August 2010 01:57 PM |
| Amplifier Design Book | pixie | Everything Else | 27 | 11th June 2010 08:36 PM |
| Project 11.1 from Slone "High-Power Amplifier" Book | Karl71 | Solid State | 46 | 6th October 2008 03:47 AM |
| book-audio power amplifier by Douglas Self | mikee12345 | Solid State | 8 | 16th November 2003 01:16 AM |
