Old 29th June 2003, 07:02 AM   #1
KCC is offline KCC  Canada
Default 5 transistors output stage
I've heard(not actually seen) that company uses five output transistors in output stage in stead of the normal two complementary pairs.I am wondering how these arrangement is made.I believe the idea is to provide more current draw. Anyone has opinions on this?
Peter
Old 29th June 2003, 08:03 AM   #2
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
Hi Peter,
If I understand you correct, you mean amps using 5 NPN and 5 PNP transistors in the output stage....
This is quite common for heavy amps, and it is done for the amp to be able to deliver more current (as you believed correctly ).
Most output transistors (espesially those used in audio) have limited Ic (current flow throug the collector) of 10-15 Amps and Ptot (the total power handling of the transistor) of 150 to 250 Watts. This means, that for the amp to be able to handle more power than one pair of transistors can handle, you have to add additional output transistors i parallel (2, 3, 4 or more...)
You could take a look at my website under projects, where you find a temporarely schematic of my LYNX power amp using 2x 4 output transistors.
Hope this was of any help.
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com
Old 29th June 2003, 11:02 PM   #3
Hi Jan,
Thanks for the quick reply. I understood the idea to use more transistor pairs to provide more current draw. And I actually built different output stages using different quantity of transistor pairs for comparison purpose. But the impression I read from this company's brochure that offer 5 transistors per side for upgrade to the Hafler DH200 amp (which using 2 complementary pairs of output transistors) that puzzles me. Obviously,4 out of the 5 are refering to two complementary pairs. So where does the lone transistor relate to?
Peter
Old 30th June 2003, 05:59 AM   #4
Jan Dupont's Avatar
Hi again,
Do you have the schemaitc of the output circuit?
I donīt recall to have seen this upgrade...
Old 30th June 2003, 09:07 AM   #5
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Originally posted by KCC
Hi Jan,
Peter
5 transistors per side refers to 5 for pos, 5 for neg side, per channel. Then in each channel you have 5 pairs.
Jan Didden
Old 30th June 2003, 09:15 AM   #6
Jan Dupont's Avatar
Janneman:
= Just an ordinary output stage using 10 transistors pr. channel
Old 30th June 2003, 01:52 PM   #7
Jan,
Ok. I think what they mean is five transistor pair per side per output stage.
For I can not figure out how a lone transistor relate to the circuit.I do not have the schematics so I can not confirm anything. Thanks for your ideas.
Peter
Looking 4 a simple NPN/PNP Output stage schematic useing Tip31C/32C Transistors?? Minion Solid State 27 20th April 2007 06:50 PM
Adding more transistors to output stage? bowdown Solid State 6 19th January 2007 07:15 PM
Has Anyone else used MJE13005's Switching Transistors for the output stage. John Biles Solid State 30 3rd September 2005 06:02 AM
Using Many Small Signal transistors for the output stage Update!! John Biles Solid State 10 14th August 2005 04:58 AM
50 Output Stage Transistors? thylantyr Solid State 22 26th April 2003 10:44 PM
Page generated in 0.07587 seconds (86.64% PHP - 13.36% MySQL) with 10 queries
Copyright Đ1999-2012 diyAudio
