#21 |
Ok....
I modified the relay board as follows: 100k log pot 2 channels to simultaneously vary resistor value 4700uf 63v cap instead of 220uf cap The result is I can vary charging time of the cap and for now fixed it at 23secs (it should be enough for the NTCs to warm up, correct?) pic of the board. Obviously the position is not definitive. I followed Andrew's advice and experimented. ![]() P.s. you can see where the holes have been drilled for the resistor/thermistor. As soon as the ntcs arrive I will be ready to fire up....also by then I will have cut down on the number of capacitors to something like 600000uf or less. I will reuse the spraque caps for a small valve amplifier (Intrigued by valves....) since they are 200v caps Last edited by Alexontherocks; 1st August 2010 at 07:22 PM. |
| Someone Has Themselves a Challenging Speaker Restoration Project! | DreadPirate | Multi-Way | 1 | 12th July 2010 05:25 PM |
| 1500VA power transformers 120V:120V | RyanW | Swap Meet | 4 | 17th February 2009 08:31 PM |
| Toroidal core for Elliott Project 89 | Flemming J P | Car Audio | 7 | 7th June 2007 05:43 PM |
| project brewing in my head, challenging, but seem like a good way to try new concepts | lemans23 | Multi-Way | 26 | 11th October 2005 12:29 PM |
| How to power up 1500VA toroid? | supernet | Everything Else | 1 | 6th May 2002 10:27 PM |
| Page generated in 0.06176 seconds (65.85% PHP - 34.15% MySQL) with 10 queries |
