After some discussion about how best to attenuate volume between a DAC and a power amp, I have ordered a simple FET buffer PCB from SKA Audio and have decided to post a build diary.
The schematic is attached below. Note that the pcb is just a prototype so does not appear to be commercially available yet. Here's a bill of materials (in case anyone is also interested in doing a build): For the pcb: 1 x 10K Stereo Potentiomenter 2 x 47R 1/4W Resistor 2 x 100K 1/4W Resistor 2 x 1uF 50V capacitors (I'm using 0.22uF polypropylene caps) 2 X 100R trimpot Remaining items: Chassis Regulated DC power supply + transformer IEC socket + fuse socket RCA jacks (input and output) 2 x 47R 1/4w Resistor (for placing from the output of the pcb to the RCA outputs) Hookup wire & Solder Knob for volume pot I'll post some pictures and further comments as it progresses, but any thoughts on the design, etc, would be great! Last edited by lordearl; 29th July 2010 at 03:51 AM. |
#2 | |
Michael Gazzaniga - "The arts are not frosting but baking soda." |
#3 |
Thanks John – what is the calculation for working out the dB range? My cd player has an output impedance of 22 Ohms and the power amp an input impedance of 100K ohms.
#4 | |
Man, get that thing into the shop and have it fixed, or get a rescue inhaler for whatever asthmatic tube output stage it's running. se |
#5 | |
se |
#6 |
It's a Sony player. I can't find the spec. sheet online, but I measured it too--it's 10k. It's probably a series resistor? I should change that to 100 ohms, if I can. Thanks, Steve!
#7 | |
Samuel |
#8 | |
#10 | |
What JFET you plan to use?
Maybe 2SK170BL 2SK170GR has got lower current, but we prefer high current http://www.ska-audio.com/Forum/YaBB.pl?num=1244063607/0 Greg says this: Quote:
lineup Last edited by lineup; 29th July 2010 at 06:18 AM. |
| Discrete buffer notion | Sheldon | Solid State | 6 | 10th September 2009 03:22 PM |
| Help a noob build Pedja Rogic's J-fet buffer | mattjk | Chip Amps | 5 | 29th July 2008 04:10 AM |
| my Pluto build diary (aussie) | gainphile | Multi-Way | 10 | 20th May 2008 12:14 AM |
| Best place for discrete buffer | Khron | Chip Amps | 8 | 11th March 2006 05:16 PM |
| Discrete buffer stage for xover | JoeC | Everything Else | 1 | 2nd February 2002 03:43 PM |
| Page generated in 0.12026 seconds (79.29% PHP - 20.71% MySQL) with 11 queries |
