Audio (Lateral) MOSFET's  for Class AB - Overview, P-Spice URL's
Old 30th December 2011, 01:15 AM   #21
ontoaba is offline ontoaba  Indonesia
ontoaba's Avatar
I usually using low bias with cross management, don't know why I am still use it when sometimes THD figures already low without it. But may be from listening test it has significant effect, so I keep using it. Error correction is also very useful.
Old 30th December 2011, 04:08 AM   #22
ontoaba's Avatar
Originally Posted by Bob Cordell View Post
It is always interesting to see approaches to achieving low distortion with low quiescent bias currents in class AB designs, if that is what you are referring to. Particularly with MOSFETs, transconductance droop at lower bias currents can be a source of distortion. That was the main reason that I introduced Error Correction to vertical MOSFET power amplifiers.
Bob
Yes, true, error correction is useful to cancel crossover error that NFB could not reject it most in 5kHz and up, and normally laterals also still need around 250mA bias to get low crossover error.
Also what peavey, I also can't found it with google, I hope anyone could show them. I don't like that spiky crossover error too. I think many people agree we doesn't like that spikes.
I am currently increasing my mosfet bias at HF operation, ofcourse not low bias anymore at high difficulty operation (waste power), but it has low bias normally 10-30mA at idle and normal operation. I still haven't other solution than this for long time.
I post old version here:
http://www.diyaudio.com/forums/every...roof-here.html
This picture help to show how it work, but I really sorry I am not sharing schematic for now. I can only share on how it work. Picture is showing output stage only without global NFB.
Old 2nd May 2012, 08:19 PM   #23
AndyVicus is offline AndyVicus  Italy
Somebody know how to get ACD101NDD lateral mosfet?
Old 3rd May 2012, 11:00 AM   #24
Have been reading any of the posts/reports re. the loss of the sole production facility due to natural disaster?
regards Andrew T.
Old 3rd May 2012, 11:33 AM   #25
No, I don't know that Proaudio factory is the same of Toshiba (fos example) factory.
So I have possibility to get one ACD101NDD? I have a final stage with 11 pair of mosfet, only one n-nos is short so I hope that I can substitute only this one, 11 pair of this mosfet is not cheap.
Old 3rd May 2012, 12:11 PM   #26
As far as I know Toshiba don't make or sell any Lateral Power mosFETs.
regards Andrew T.
Old 3rd May 2012, 01:36 PM   #27
Thank you very much, now that I know that I'm very happy. You was very usefull.
Old 3rd May 2012, 01:54 PM   #28
nigel pearson is offline nigel pearson  United Kingdom
Default Exicon
Do you guys use Exicon FET's
Lateral Mosfet
Old 3rd May 2012, 02:06 PM   #29
But if I change type of mosfet I have to replace all 22 transistor and it is very expensive.
The ACD101NDD is a 24A driver.
Old 3rd May 2012, 02:30 PM   #30
Tekko is offline Tekko
Banned
Last time i found a genuine legit datashhet for the ACD100NDD, it was a 16A part, dual die version of the ACD100NSD which is rated to 8A.
THe "SD and "DD" stand for "single Die" and "Dual Die"
The datasheets supplied by class-d.com are incorrect.
Audio (Lateral) MOSFET's  for Class AB - Overview, P-Spice URL'sHide this!Advertise here!
Spice models Exicon MOSFET's TS Solid State 4 12th February 2012 02:00 PM
Class AB, Class AB Non-Switching, Class AB Soft Non-Switching steph_tsf Solid State 4 15th March 2010 04:39 PM
Looking for lateral mosfet spice models ojg Solid State 3 16th November 2003 12:56 AM
JLH Class-A in a with MOSFET's tschrama Solid State 3 10th February 2002 04:23 PM
