Matching jfet at what voltage?
Old 28th July 2010, 11:51 AM   #1
Sunsun22 is offline Sunsun22  Hong Kong
Sunsun22's Avatar
Default Matching jfet at what voltage?
There are a number of articles suggesting matching jfets, usually at 10V. Yet, if my circuit works at, say for example, 20V, should I adjust the voltage of the matching circuit to 20V?
Old 28th July 2010, 01:53 PM   #2
lineup is offline lineup  Sweden
lineup's Avatar
Yes, I would use 20 Volt.
Matching at 10 Volt would most probable be good enough,
but I like to match at the level devices should work.
When matching high power transistors, it is not as easy
to setup a situation with lots of power and heat.
But for small signal JFET and BJT this is less of a problem.
lineup
Old 28th July 2010, 02:23 PM   #3
R.I.P.
jFETs may not be at their best with 20Vds
I agree test/measure/match devices for the operating conditions of the application. Vds, Id, Tj/Tc,
regards Andrew T.
Old 29th July 2010, 11:57 AM   #4
Sunsun22's Avatar
Thank you for the input.
Matching jfet at what voltage?Hide this!Advertise here!
JFet matching and measured distortion - Part1 h_a Solid State 22 27th March 2009 06:41 PM
Ono JFET matching AuroraB Pass Labs 12 26th July 2007 12:20 PM
JFET in-circuit matching Leolabs Solid State 5 9th April 2006 01:44 PM
JFET matching Nelson Pass Pass Labs 19 19th February 2006 03:31 AM
